Results 1 to 9 of 9
    Jul 2019
    The Transmission Woes - Continuation Post
    So - I hit this girl with my code reader and found a few other issues rather than just the gear 1 ratio code so I’m wondering if it doesn’t have some sort of Electrical component that has officially taken a dive down the crapper...especially based on what I’m seeing. What do y’all think?
    Jul 2019
    That’s basic info on the codes - more the less stuff I’ve already seen. I appreciate having that to go to by all means but the question really is more toward replacement of the trans or drain and fill the fluid
    Nate
    Jun 2019
    I replaced my computer (PCM) after experiencing similar code on my 06 Magnum - Took it to Dodge as the car was falling on its face "occasionally" Really awesome pulling onto the freeway
    They said you need a computer, we can't see past the PCM to look the the TCS Malfunction. Dodge wanted $1200, I said nah paid my $95 daig fee, and bought a refurb unit.
    All my transmission stuttering engine stalling etc were solved...and it comes with a lifetime warranty to boot...
    Good luck!!
    Jul 2019
    So - in an oddly bizarre turn of events; I cleared the codes out of this thing 3 days ago. Just went and drove it around for a little while, got the temps up where I figured they should be and it hasn’t thrown a code yet (knock on wood)
    Makes me wonder if his PCM is screwed or if it was something more along the lines of a dirty transmission or clogged cooler
    Sep 2018
    Cartersville, GA
    Curious where you are with this? I just had a similar issue... Car has been driving fine with no issues and then i'm leaving Walmart and I hit the gas pretty hard and heard what I believe to be the pump winding! All of a sudden I lose all gears and i'm coasting and had to push it into the gas station, I let it sit for about an hour and made it about 200 feet and it started again, After about the 5th try the check engine light came on and I barely made it home. The last couple miles it stopped and I let it sit over the weekend and took it to get a diagnostic done and it threw 12 codes which a few were the same. P0700, P2784, P0730, U140B, P0731, P0732, P0733, P0734 ! It didn't act up while driving to the autopart store but it wasn't very far either.
    Jul 2019
    Right here - replacing this first before I buy a trans
    Sep 2018
    Cartersville, GA
    Good deal, Let us know the outcome.
    Jul 2019
    I went ahead and got the dipstick as well just to have it. This one is hard as all hell to read which isn’t a surprise by any means (thanks Amazon ha!) and the fluid doesn’t smell burnt nor does it look horribly bad either.
    The connector should be here tomorrow; when these things are disconnected IF they are leaking is it advised to clean the connector out with an electrical connector spray just to eliminate any issues or no?
