Results 1 to 6 of 6
    Nov 2018
    INDIANA
    06 srt8 axle upgrade
    Would I be able to use axles from a 2010 charger rt?
    Dec 2016
    Charlotte NC
    No. But a full up grade would be a GETRAG rear carrier swap. This would give you 226mm axles and LSD. GETRAG 3.06's are pretty easy to find. There
    is a guy around selling brand new 3.91 GETRAGS for $800.00.
    Nov 2018
    INDIANA
    Why not ? They are the same size
    Dec 2016
    Charlotte NC
    Quote Originally Posted by JTS61 View Post
    They are not the same size nor spline count. I think the 10' R/T's are 30 spline and the 1st Generation SRT's 27 spline.
    Nov 2018
    INDIANA
    I’ve located a few 3.06 Getrag carrier assemblies.what else is needed ?
    Dec 2016
    Charlotte NC
    You will need the GETRAG carrier, axles,hubs, pink bolts and nuts, 392 coupler, longer GETRAG mounting bolts and a couple other mounts/shims. And since you have a 4 bolt SRT driveshaft you will need the rear section of a early RT or 300C 3bolt driveshaft.
    Thanks JTS61 thanked for this post
