15+ spoiler on 06?
2K views 6 replies 4 participants last post by  UpInSmoke
#1 ·
#2 ·
The trunk spoiler? If so I’m waiting on it to be painted.
#4 ·
#5 ·
Yeah I've put one on before. Just make sure it can flex because it needs to bend to fit the contours of the 1st Gen trunk.
#7 ·
Bolts primarily with the 3m tape to keep stuff from getting trapped underneath it. Center the spoiler on the decklid & mark the center whole. Drill & mount with the center bolt only. Now since it's stabilized I pushed each side down to the contour of the trunk and marked the outside holes. Removed the spoiler to drill the outside holes then reattached starting with the center hole and snugged that up. Then got each side bolt started and tighten each up a little at a time going back & forth to keep pressure even. Wasn't trying to crack it!? Once all 3 bolts we're snug I pulled the cover strip off the 3m tape & then tightened the bolts all the way up. If your on Instagram check out @srtross. I did it on his charger along with the wicker bill
