Results 1 to 9 of 9
    May 2018
    Power Outlet Install
    I did a search but found nothing about this issue. I want to move the cigarette lighter/power outlet from inside the ashtray, I'm tired of having to have that thing open just to charge my phone. Has anyone moved the power outlet to another location, and where did you move it to? I was thinking about the side of the console, but that isn't very convenient. I realize that there is another power port in the console, but that is on all the time and I don't feel comfortable leaving my phone charger plugged into it all the time as it tends to get fairly warm. I would appreciate any suggestions, especially any with pictures. Thank you.
    later,
    KrustyTC63
    May 2011
    Markham, Ontario
    I use the console plug. I just unplug the charger when not in use. I've also installed a plug at the lower rear end of the console for my daughter to plug into when she's sitting in the back
    2006 300SRT8
    SOLO Performance Mach X3 SRT exhaust / LMI V2 True CAI / Eibach Sways / StreetEdge coilovers / Trufiber hood / AMG paddles w/TRS300 wireless controller / Grant Revolution steering wheel / Arrington strut bar / BT engine bling incl. uni-strut caps / Rohana RC-10's / Kaption Audio amps, sub and speakers / Interior switch lighting by Diboblo / Instrument cluster by Black Cat Automotive and Tim Stone (TRS300) / StopTech SS brake lines
    Likes Carpaltomo liked this post
    Jul 2018
    Quote Originally Posted by BryGuy View Post
    I would think you can put them wherever you want as long as you have some wire, a way to run it, and a power source
    May 2018
    Nice clean install BriGuy! I appreciate the picture. I think I'll try your idea. I was actually thinking I might install a switch in the console to turn off the outlet when I'm not using it. If thats the route I go, I'll be sure to post a pic.
    KrustyTC63
    Sep 2013
    Louisville, KY
    Why not use the one inside the center console?
    Likes TEDDYSRT liked this post
    May 2018
    Quote Originally Posted by RDT View Post
    Because I don't want to leave my phone charger on 24/7.
    Mar 2017
    Bedford, Texas
    Quote Originally Posted by KrustyTC63 View Post
    If it's not actively charging your phone it's not "on" lol, it's just sitting there. Mine has a little LED that stays lit, but it doesn't use enough juice to hurt a thing.
    It won't get hot if it isn't charging your phone either, there's no juice running through it.
    Apr 2017
    Redlands, CA
    Then move that fuse in the trunk to be ignition on and not always on position, problem solved
    [CENTER]2006 300C SRT8
    2017 Hellcat exhaust / MF High flow cats / LMI Air Hammer / Mopar Perfomance TCM / Diablo Trinity / Johan (Diablotoona) Tuned / Pedders TrackII springs and shocks / '16 Scat pack front sway bar 32mm / Bwoody Hellcat front end links / Arrington billet strut tower brace / UPR pro series bump stop kit / Custom Air-Oil separator all braided lines & AN fittings/ Mishimoto 180* T-stat / Speedlogix billet front adj control arms / HyLift Johnson roller lifters -What "Hemi tick"/ + HRF
    [/CENTER]
    May 2011
    Markham, Ontario
    Quote Originally Posted by TEDDYSRT View Post
    The fuse in the trunk only controls the front power plug, not the one in the centre console.
