Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Mar 2017
    Bedford, Texas
    Do-able; but be aware that just outside of the insulation is where bending will be concentrated. The other concern is the low temp solder used and its actual durability...
    Hence the "if they work as well as advertised" :^)
  2. #17
    Oct 2015
    I'm reading the service manual now and I found what I'm experiencing on page 2334 under the heading *ALL DOORS FAIL TO LOCK.
    When it refers to the "cluster" is that the Driver Door Module in the door? It makes me think dash cluster when it just says Cluster.
    Edit: I found out yes, its the harness that goes in to the cluster.
    The proposal in the manual then is to test each wire related the locks by unplugging this harness, by taking about the dash presumably, then take apart the door so you get access to both plugs on the harness?
  3. #18
    Dec 2007
    Riverside, California
    Quote Originally Posted by kott0n View Post
    Yep.
    They want you to test end to end, to find the broken wire(s).
    In the manual, the cluster is the speedometer. It is a module, like other modules.
    If you go to section 8W, in the manual, you can see which wires come from the door, to the speedo. This will help narrow down which ones you're looking for.
    Bob
    http://www.luxte.ch
    Lux Technologies
  4. #19
    Nov 2009
    Niagara Region,Canada
    Or just pop open the passenger door panel, unplug the lock and apply voltage to see if it still works...
    this before you go through the wiring checks...at the most, you know that the parts work then.
  5. #20
    Oct 2015
    Quote Originally Posted by foxtail View Post
    Since the schematic shows all 4 doors part of the same schematic, if the passenger door lock is dead, would that make all the locks function erratically?
    This sounds like either way would be a good test to do.
