Results 1 to 7 of 7
    Mar 2014
    Torque for Stabilizer bar bolts
    I'm changing the below: (2016 Challenger Hellcat)1) Stabilizer bar bushings only (4 bolts) 2) Left and right Stabilizer Bar Links (upper and lower bolts)Does anyone know the torques specs for these ?http://www.aanning.com/AJISSUES/Hell...r/SWAYBAR1.jpg
    Calgary, Alberta
    Just tight enough...its not that critical :^)
    Mar 2016
    N. GA
    LoL, if you don't know just say so..., or don't post.
    2013 Dodge Charger R/T Plus, Edelbrock E-Force 2300TVS 6.4 PSI, Mustang-Dyno Tuned 418hp/430tq, 3.06:1, Severe Duty Radiator, Dual Fans, OE Oil Cooler, Pursuit BR9 Brakes, Corsa CatBack, Bilstein Dampers, Catch Can, AlfaOBD enabled Sport Mode & SRT Pages, Fogs on w/High Beams, Add Reverse Cam & Auto Dimming & Tilt in Reverse Left Door Mirror.
    Sep 2012
    Toronto, ON, Canada
    Oct 2019
    The manual for a 2019 Charger HC, likely the same as Challenger and likely has not changed at all since Hellcats first came out, lists the end link to bar nuts at 100 foot pounds, the end link to the strut at 111 foot pounds, and the bar to the crossmember bolts at 48 foot pounds.
    Likes Ultimagic5, snobrdrdan liked this post
    May 2018
    Shirley, MA
    1971 Dodge Demon 340
    2006 Dodge Magnum RT 5.7
    The Demon Chronicles
    May 2018
    Shirley, MA
    2 ugga-duggas
