Add strong lift points and extra rigidity to your 2008-newer Challenger with bolt-on Chassis Jacking Rails (CJR110) from BMR Suspension. Jacking the car on the pinch welds can easily damage the pinch welds and floor pans, eventually causing panel misalignment. Built from heavy-duty 1 x 2-inch boxed tubing and 3/16-inch laser-cut, CNC-formed steel plate, BMR’s Chassis Jacking Rails are designed to give you a rock-solid jacking or jack stand point for your 2008-newer Challenger. BMR Suspension designed the bolt-on Chassis Jacking Rails for performance and street applications. These chassis jacking rails use existing boltholes and hardware, allowing for easy installation with simple hand tools. With BMR’s jacking rails, the entire side of the car can be easily jacked up from one jacking location. These jacking rails also add strength to the chassis by reducing flex. Installation time is about 1 hour. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
