Results 1 to 6 of 6
Thread: Brake dust
    Mar 2018
    Brake dust
    What’s good for removing drake dust
    Nov 2013
    South Florida
    I use diluted Chemical Guys wheel cleaner. First I spray with the foam bath that the car gets, then the wheel cleaner. Then I use a soft wheel brush dipped in the car soap to loosen and remove most of the dust. I then follow up with a mitt and more soap to remove everything. Then a rinse.
    Most importantly I coat with either a ceramic type wheel coating or sealant after every wash to make sure that any future brake dust has a hard time sticking and is very easy to remove the next time around.
    Always use the two bucket method and dedicated wheel only mitts/brushes/sponges. I use a stiff carpet brush for the tires and a stiffer rounded end paintbrush about 1" wide to clean the area around the lugnuts, center caps, embossed logo, and brake calipers. I just dip it in my foam bath bucket and let it foam up from the brush.
    Brush:
    Amazon.com: Chemical Guys ACC_G08 Short Handle Wheel/Tire Brush: Automotive
    Wheel Cleaner:
    Amazon.com: Chemical Guys CLD_203_16 Signature Series Wheel Cleaner (16 oz): Automotive
    Soap:
    Amazon.com: Chemical Guys CWS_107 Extreme Body Wash and Synthetic Wax Car Wash Shampoo (1 Gal): Automotive
    Wheel Coating:
    Amazon.com: McKee's 37 MK37-240 Wheel Coating, 4 fl. oz.: Automotive
    Tire Brush:
    Amazon.com: Mothers Carpet & Upholstery Brush: Automotive
    2006 300c SRT8
    PWR Ported Heads | HHP Stage 2R Cam | 3.55 Getrag | GTP Ported Intake Manifold | Kooks Longtubes | Corsa Sport / SRT Resonators | AMG 8 Piston Brake Calipers | Hemituner 6,800 TCM | BT Catch Can | LMI True CAI V2 | Tranzformer | MM 87mm TB | Johan Tuned | REM Adjustable Endlinks & Front/Rear Shock Braces | 33/22mm Front/Rear Sway Bars | Michelin Pilot Sport 4 315/35/20 & 275/40/20 | 10" Widened Oem Wheels | LC-2 Wideband Analog Output to Trinity | Mishimoto Full Aluminum Radiator
    Thanks NH_Scat thanked for this post
    Nov 2013
    South Florida
    Also depending on how the current finish is on the wheels, you may benefit from a claybar, compound, polish, and sealant. The more flat, smooth and slick the surface is, the harder its going to be for dust or dirt to stick to it.
    Jul 2016
    Madison, WI
    Brake Dust Professional 32oz
    Haven't used anything better
    Sent from my Pixel 2 XL using Tapatalk
    Oct 2017
    Snellville, GA
    Good information, I was going to ask the same question as it seems my wheels are constantly covered in brake dust all the time as well, not so much after washing though.
    2012 300 SRT8 exhaust, intake, tuned, 180 thermostat, oil catch can
    2011 M37s 22's, BC coil overs, exhaust, intake, other small stuff
    2006 Land Rover (Wife's Ride) 22's
    2012 Camaro LS (wife's Ride) 22's, exhaust, intake, stereo upgrade
    2012 Hyundai Veloster (Daughter's Ride)
    2004 Impala SS Supercharged (Sold)
    2004 Escalade (Wrecked) 22's DVD's
    1999 Dodge Durango (Sold)
    1996 Accord heavy Modded (Traded)
    1995 Impala SS heavy Modded (Sold) Gone but not forgotten
    Aug 2007
    West Palm Beach, FL
    Quote Originally Posted by NH_Scat View Post
    Brake dust is a pain! The best option in my opinion is a brake pad that provides little to no dust. I have the Power Stop Z23 pads on my SRT Challenger and I am very happy with not having to clean the brake dust off every time I drive the car.
    Do you have the 6-Piston or 4-Piston calipers on your Scat Pack ?
    - Alexis
    Sales and Support | Speedlogix, Inc.
