iF HOOD IS OPEN CAN THIS SWITCH DRAW JUICE FROM BATTERY, ESPECIALLY OVER 2 MONTHS??
\sorry for the caps.
PB 0-60 3.24 MIR Raceway Drag Radials 6/18
PB 60' 1.472 @ CF9 4/18
PB ET 1/8 6.911 @ CF9 4/18
PB MPH 1/8 101.32 @ The Rock 4/19
PB ET 10.857 @ CF9 4/18![]()
PB MPH 127.29 @ Atco 11/18
I hesitate to link a Scotty Kilmer video but he has a cheap solution if you don't have an amp meter.
How to Fix Battery Drain in Your Car (Parasitic Draw Test) - YouTube
How to Perform a Parasitic Draw Test on Your Vehicle - Diagnosing Battery Drain Issues - YouTube
Diagnosing Battery Draw (Battery Goes Dead Overnight) - YouTube
Which Parasitic Draw Test Method is REALLY the Best? - YouTube
What’s strange about my scenario is that if I do not put a trickle charger on it then not only will the battery go dead, but it will go stone dead and need replacement. Strange
there is parasitic draw 1.20, not sure from where yet.
Start pulling fuses I guess
Find the fuse for the remote start pull it and see what happens
I've never been able to leave my Maggie sit for more than maybe 2-3 weeks before the battery is dead (last 7+ yrs I figure). Using a yellow top. I think all cars now have a slow drain that will kill any battery after 2-3 weeks if not left on a trickle charge. I just disconnect the battery now if I know I'm not going to start her for the next week or more.
How quick does the battery go dead?
I had a problem with battery drain, found my cluster was not going to sleep.
Pulled all fuses and relays, still would not go to sleep.
Pulled power lead from under hood fuse box and the cluster would go to sleep.
Pulled fuse box and fooled with the wiring mess, put back together and the problem went away.
Really odd.
13 Chrysler 300S, Stock 17 RAM 6.4 BGE with TSP Stage 4 boosted Cam, AIT 18% OD pulley, E-force 2.62 pulley(12.2 lbs boost),, Fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, 3" Magnaflow Cat-back, FTI 2800 stall, Trans by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. aluminum rad. SRT fans. Brembo upgrade. Stage one MOPAR springs, XIX X39 22x9 +15 - 22x10.5 +22 with NITTO NT555 265/35R22 - 295/30R22
