Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    May 2011
    Toronto, Ontario
    Quote Originally Posted by someotherguy View Post
    I haven't noticed (but also haven't looked for) any hood switch on three '06 models and one '05, so I wonder if your car has remote start - that might be a switch that prevents remote start if the hood is open.
    Richard
    That's exactly what it's for. I bought a factory one and used it for my aftermarket remote start unit. I hated the idea of using the cheap looking pin switch that usually comes with all aftermarket kits.
    2006 300 SRT8 / 2012 300 SRT8
  2. #17
    Jan 2011
    Calabash, NC
    iF HOOD IS OPEN CAN THIS SWITCH DRAW JUICE FROM BATTERY, ESPECIALLY OVER 2 MONTHS??
    \sorry for the caps.
    PB 0-60 3.24 MIR Raceway Drag Radials 6/18
    PB 60' 1.472 @ CF9 4/18
    PB ET 1/8 6.911 @ CF9 4/18
    PB MPH 1/8 101.32 @ The Rock 4/19
    PB ET 10.857 @ CF9 4/18
    PB MPH 127.29 @ Atco 11/18
  3. #18
    What’s strange about my scenario is that if I do not put a trickle charger on it then not only will the battery go dead, but it will go stone dead and need replacement. Strange
  5. #20
    Quote Originally Posted by Tdola View Post
    Batteries don't like being totally discharged. That is what deep cycle batteries are for maybe.
  6. #21
    Some battery chargers such as the one I bought from Walmart are "smart" chargers and have a setting for restoring a dead battery. Might work?
  7. #22
    Jan 2011
    Calabash, NC
    there is parasitic draw 1.20, not sure from where yet.
  8. #23
    Nov 2010
    Start pulling fuses I guess
  9. #24
    Jan 2011
    Calabash, NC
    Quote Originally Posted by Renfrick1 View Post
    Is the trunk open??
    trunk closed now open and i took out the light. still have 1.36 amps? draw,.
  10. #25
    Aug 2012
    iowa
    Find the fuse for the remote start pull it and see what happens
  11. #26
    Nov 2008
    I've never been able to leave my Maggie sit for more than maybe 2-3 weeks before the battery is dead (last 7+ yrs I figure). Using a yellow top. I think all cars now have a slow drain that will kill any battery after 2-3 weeks if not left on a trickle charge. I just disconnect the battery now if I know I'm not going to start her for the next week or more.
  12. #27
    Feb 2018
    Boca Raton, fl
    How quick does the battery go dead?
    I had a problem with battery drain, found my cluster was not going to sleep.
    Pulled all fuses and relays, still would not go to sleep.
    Pulled power lead from under hood fuse box and the cluster would go to sleep.
    Pulled fuse box and fooled with the wiring mess, put back together and the problem went away.
    Really odd.
    13 Chrysler 300S, Stock 17 RAM 6.4 BGE with TSP Stage 4 boosted Cam, AIT 18% OD pulley, E-force 2.62 pulley(12.2 lbs boost),, Fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, 3" Magnaflow Cat-back, FTI 2800 stall, Trans by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. aluminum rad. SRT fans. Brembo upgrade. Stage one MOPAR springs, XIX X39 22x9 +15 - 22x10.5 +22 with NITTO NT555 265/35R22 - 295/30R22
