Results 1 to 8 of 8
Thread: rust question
    Mar 2015
    DesPlaines Il.
    rust question
    Hey gang,
    I'm considering adding a new Challenger R/T alongside my SRT8 Maggie. This will be a summer car, but used in all summer weather (rainy days, etcetera). The rest of my summer cars don't even get wet, heh heh.
    Anyways, here in the Chicago area I am seeing more and more of the earlier Challengers showing rust through ahead of the rear wheels......like ventilated quarter panel rust through, not just surface.
    I remember some time ago that Dodge was repairing these under the rust warranty but am wondering if they changed the construction method to reduce the rustout tendency. Memory says it was often a result of a spray foam sound deadener that had been applied during assembly.
    So, my question is twofold: 1. Did Dodge change the construction method and or, 2. Has it been determined this is a salt belt issue only or is it happening to all Challengers regardless of where operated (like water entrance and retention).
    Thanks in advance for any input.
    Rob
    Jan 2016
    I, like you don't drive my 2006 Charger R/T in winter or rainy days. I never heard of rust warranty problems with early LX. Maybe someone can enlighten us.
    Likes Ultimagic5 liked this post
    Sep 2018
    Springfield, MO
    If there was\IS a rust warranty...sure wish I knew that before I cut and welded new rear wells in mine
    Mar 2015
    DesPlaines Il.
    Mopar has a five year unlimited mileage rust through warranty on finish painted body sheet metal......it is in your warranty manual. I mentioned it because I had heard rumor that they (Dodge) were doing repairs on a case by case basis beyond the original coverage.
    Ultimagic5?
    Was your car operated in a salty environment like I deal with in Chicago or do you think your corrosion was caused by poor water drainage in the quarters?
    Rob
    Sep 2018
    Springfield, MO
    Quote Originally Posted by Robby View Post
    Ultimagic5?
    Rob
    I'm not entirely sure of the vehicle location history, I can't recall the Carfax details
    I bought it in Missouri 2 years ago and it still resides here. We do love to salt the s*** out of our roads, so take from that what you will.
    Aug 2009
    Quinlan, Texas
    My wife's 392 '12 Challenger has rust on the strut brace and on top of the radiator core support. We are in Texas and she rarely drives it-(10,000 total miles). My '05 Magnum has no rust anywhere. Maybe a paint change or something.
    2005 MAGNUM R/T
    JBA headers, Blastin Bobs 9db pipes,, Stack Performance strut brace, Stack performance chubby sway bars ,SRT springs ,Bilstein struts & shocks, Getrag 3.91,, Cams solid rear cradle bushings, Blue Tops, BT Catch Can. Other BT goodies.
    2012 Challenger 392 SRT (Wife)
    Jul 2020
    Tampa,. FL
    "Maybe a paint change or something."
    Yup, a good paint job should do the trick. Of course, you'd also need very skilled hands on the job as well.
    Jul 2020
    Tampa,. FL
    Oh, may I ask, what specific paint would you replace it with?
