Had same issue search bwoody he makes a kit that resolves this When you do the srt drop kit it induces this wear.
You will see his kits call out the length change when you lower
There notes
Control Arm info:
.120" longer arms: Accommodates LX models Lowered with a 1.0" - 2.0" drop, These arms will adjust you back to Factory Alignment Specifications.
Fixed control arms: These arms are stock length.
Made to replace the flimsy pressed sheet metal / Aluminum control arms with rubber bushings. These BWoody arms are constructed of 3/8" thick A36 steel and as always.. polyurethane bushings as well as grease fittings. Our upper control arms are proven to greatly reduce wheel hop, and are the ONLY arms on the market which bend at the same radius as OEM to provide suspensio
