Results 1 to 15 of 17
    Jul 2010
    Toronto, Ontario
    Question Cooling fan/shroud noise/vibration
    Hey LXF,
    I've been trying to isolate this problem I have with my cooling fans on my 2010 Challenger SRT 6 Speed.
    A few months ago I've been hearing sounds from one of the fans after engine shut off....after shut off
    one of them made a "wobbly sound" like it was loose or coming off. I figured it was dying....
    This last week after city driving (warm days) the fan assembly started making a louder squeaking sound
    and the whole rad support/fan shroud/grill/nose assembly started shuddering violently; but my temp gauge was still at normal
    levels & the engine kept running. This happened twice in the last 7 days. Otherwise all is ok and no sound/vibration occurs.
    I am taking the chally to the dealership; but don't know what to tell them or how to replicate this intermittent problem.
    I don't want this to cause me to have a roadside breakdown & be stranded.
    Anyone have any input on this issue....any advice welcome...thanks in advance !
    Feb 2012
    Houston TX
    Replace that fan assembly before it grenades and eats your radiator. $$$
    Your vehicle may (or may not) fall under a recall for the fan blades; earlier SRT's were. The blades themselves would come apart. Problem is, dealer just replaces the blades, not the whole assembly. Results of that job can vary. Mine were out of balance after the replacement blades so I just cashed up myself and replaced the whole fan assembly on my own.
    Richard
    Thanks HemifeverAZ, jjo thanked for this post
    Likes HemifeverAZ, jjo liked this post
    Jun 2019
    Looks like this mine let go last week 09 srt 6speed 100,000 miles I recommend the new brushless from dorman see rockauto better improved designed. I’m doing mine with a new Ron Davis radiator
    Thanks someotherguy, jjo thanked for this post
    Feb 2012
    Houston TX
    Quote Originally Posted by HemifeverAZ View Post
    Ouch! Sorry it happened but it's also good confirmation that an 09 can suffer the same fate the earlier years did. I don't know what all years are covered under the recall for the blades.
    Richard
    Jun 2019
    Quote Originally Posted by someotherguy View Post
    Richard
    Doesn’t show up on alldata
    Jun 2019
    This week get the new one in an ron returned my unit ready to go
    Jul 2010
    Toronto, Ontario
    Thumbs up
    So this is your/our OEM Fan assembly after it grenaded ? One fan lost all the blades ?
    Wow...that's dangerous...So u recommend the Dorman from Rock auto, how much did that set u back
    if u don't mind my asking ?
    Thanks again bro !
    Jun 2019
    Yes correct
    I did go with the new dorman after talks with Ron Davis he uses the brushless on custom builds which dorman did, if you want to keep no codes an tuning you want to use the oem replace /upgrade
    This fan fits from 09 to 18 srt model that had a 2 fan application
    If you go custom must have tune custom an independednwiring due to the high speed low speed ecm functions
    Jun 2019
    Quote Originally Posted by jjo View Post
    Thanks again bro !
    $252.79
    New improved design
    To get discount an parts at dealer must assemble an cost more highlighted in yellow with my dealer discount was all parts for fan to replace new , not sold as assembly. Also not brushless fans on the oem
    Side note the Dorman brushless is what corvettes have been using for years now
    Jul 2010
    Toronto, Ontario
    Talking
    Thanks for all the info HemiFeverAZ...much appreciated !
    Jun 2019
    That’s what where here for
    Feb 2012
    Houston TX
    I just dug up the info again -
    June 2011 Customer Satisfaction Notification L08
    Engine Cooling Fans
    2006 - 2008 (LX) Dodge Charger, Dodge Magnum, and Chrysler 300
    NOTE: This notification applies to all of the above vehicles equipped with severe duty engine cooling (sales code NMS) or vehicles equipped with (sales code XDL
    or XDK) with “sold to” sales codes and/or are currently registered in warm climate states, built through April 29, 2008 (MDH 042912).
    No mention of Challengers and definitely not any from 09-up. I guess though in your case at 100K miles it's hard to be surprised they let go. It is disappointing that they seem to feel the newer years aren't affected.
    Richard
    Jul 2010
    Toronto, Ontario
    Exclamation Video of the fan/engine shudder....
    So this intermittent problem happened again & I finally got to video it on my iPhone.
    What do you think guys ? Coolant was at proper levels and temp gauge was normal (although it was a hot day in bad traffic) ....
    Pls turn up the sound...
    Fan shudder - YouTube
    Any help/input welcome...pls & thanks !
    Mar 2016
    N. GA
    I had a noise that sounded like a fan that was the water pump.
    Although it doesn't sound like a water pump in your video, it only takes a minute to take tension off your belt, grab the water pump pulley and see if it flops around.
    2013 Dodge Charger R/T Plus 362.63HP/389.58TQ
    Thanks jjo thanked for this post
    Likes HemifeverAZ liked this post
    Jun 2019
    Good old bad bearing syndrome hope while there you did idlers tensioner am belt
