Results 1 to 10 of 10
Thread: 02 was seized
    May 2018
    Antioch IL
    02 was seized
    09 challenger Srt8, 76k miles
    Was getting a P0420, replaced post cat 02, nothing. Went to check primary 02 and dam near broke things getting it out. I am thinking this is the cause of my code, but really wth caused it to get dented AND threads seize?
    IMG_20190511_171328761 by Corey S, on Flickr
    IMG_20190511_182710288 by Corey S, on Flickr
    Does the cat usually only fill half the space? And there is no gasket between header and mid pipe eh just a metal to metal.
    IMG_20190511_182646165 by Corey S, on Flickr
    2009 Challenger SRT8-mine2010 Challenger RT- pops
    Mar 2016
    DE
    The dent looks pretty fresh. You sure you didn’t do that damage while removing it?
    May 2018
    Antioch IL
    Thats pretty impossible.
    Mar 2016
    DE
    Quote Originally Posted by ithurtz View Post
    Possible by unthreading it then bending it over pretty hard
    Mar 2017
    Bedford, Texas
    The code is for the cat, and based on the pic down the pipe, I see why you have it. It's got nothing to do with the sensors, your cat is broken.
    With it broken and having fallen down, it probably generated so much heat it welded the upper in the bung.
    Material bouncing around in the pipe from it is probably what dented that sensor.
    There IS a gasket between the mid and the exhaust manifold, it's probably still stuck to the manifold and looks like part of it.
    May 2018
    Antioch IL
    Well dam. New cat or gut it and try to fool the 2nd sensor and pass emissions so I can renew my plates.......
    I guess thats the gasket and the header doesnt have a donut flange.
    IMG_20190511_182752425 by Corey S, on Flickr
    Mar 2017
    Bedford, Texas
    I didn't think there was on on mine when I removed them, and I had less than 15k miles on mine.
    It's not the fat donut we're used to seeing, it's just enough to seal it off when they're mated up and bolted together.
    I think you're going to be about the same, cost- wise, replacing it or tuning it out.
    If you break the material up and gut it, you'll have to put a non fouler in which might trick the computer long enough to pass inspection once it's readied up.
    I'd hit the "Want to buy" section and see who has a set to sell you. You'll be better off that way with the cost and the threads will be better on the front one.
    May 2018
    Antioch IL
    Went the "cheap" route, brother cleaned up the threads, got the big daddies angle and cel cat fix spacers. Gutted what was left of the cat, about a handfuls worth left Deleted the code, checked for leaks, then the night time gym drive was canceled due to rain, maybe this weekend. Sounds nice though, has a little louder boom to it with the jba catback, barks pretty good too.
    Mar 2017
    Bedford, Texas
    Did you gut both of them or just one?
    May 2018
    Antioch IL
    Just the driver side, want to make sure these adapters work before I screw myself over twice.
