Results 1 to 13 of 13
    Aug 2012
    iowa
    can't get brakes and clutch bleed and need help
    SO i got the idea to powder coat my calipers. i pulled the lines off and brakes and capped the lines off with rubber caps. took about 2 weeks to powder coat the calipers.
    i put new seals in and new dust boots I DID NOT CRACK THE CALIPERS IN HALF.. i put everything back together and i can not get the system bleed. also put brand new stoptech s/s brake lines all the way around.
    i bought a motive brake bleeder and tried bleeding the brakes that way.. didn't work.. i then went old school pump up and tried that way.. got clean fluid to the brakes.. brakes still go to the floor.
    clutch does not feel BAD but not quite right..
    if you pump the brakes it feels good then pump the clutch about 2 - 3 times then try the brakes the brakes go to the floor.
    anyone have any suggestions? has anyone powder coated there calipers? did you split the case? any suggestions.. this car is not stock ( motor blower ect ) i am scared to go to a dealer and a. pay for what they want to fix it if they can..
    b. if they flash the car i am stuck as the tune is for the blower cam ect and i CAN'T have them do that.
    any suggestions would be great
    thanks
    chris
    Jan 2016
    The only thing I can think of is you got air in abs unit. May have to follow service procedures to bleed ABS. What about gravity bleeding?
    Aug 2012
    iowa
    I have tried to find service procedures and all I find is plugging in a star scan to activate the abs module. I want to avoid that if possible
    Not sure but I am at a loss.
    I have tried both manual bleeding and pressure bleeding with no resluts
    Aug 2012
    iowa
    well no luck. tried and tried.. no air in the lines i can see but pedal is still messed up..
    the rears feel goofy.. when you bleed the fronts you get full pedal depress when the bleed screw is open. goes to the floor.. but the backs it feels like the pedal only goes down 1/2 way. makes no sence at all
    Nov 2018
    I had this happen on a gmc truck. i had to take it in to have the ABS module bled with the $2k scanner.
    Mar 2010
    Calgary Alberta
    I have heard of this before, just can't remember the solution. Have you tried bleeding the ABS unit each line?
    What about bleeding the system with the engine running and the ABS off (pull the fuse)?
    Hate to say this but you might have to take it to a dealer that is mod friendly and reload the factory tune in their shop and then once they are done put your custom tune back in before they start it up.
    Aug 2012
    iowa
    Got it done. Got this
    Autel
    This purges abs system
    Mar 2010
    Calgary Alberta
    Excellent, where did you find that?
    Glad you didn't have to take it in to dealer.
    Aug 2012
    iowa
    Calgary, Alberta
    Quote Originally Posted by us1champ View Post
    Autel
    Good to hear Chris. Now you can advertise / rent the unit out and recoup :^)
    Aug 2012
    iowa
    I am glad it works and for the money it is a decent tool that does more than just abs stuff
    Good to add to the tool collection
    Since the system is a dual system, if one half is air free, the pedal should only go down half way because two wheels have functional brakes. Right? Seems to me there is still air in the rear system?
    Nov 2018
    Looks like a nice little unit for the price! Might have to invest!
