Results 1 to 9 of 9
    Dec 2018
    [Q] Manual trans removal w/ - Engine in car.
    Hi All -
    I was wondering - when removing the manual trans out of a Challenger - can you leave the bell housuing/clutch intact and just remove the trans?, for instance when needing to replace the slave cylinder?
    When I did the engine - I just pulled/installed everything as one piece.
    TIA.
    Aug 2012
    iowa
    Yes you can. Just be prepared not a lot room to do much
    Dec 2018
    Yup - LOL, I know.
    Dec 2014
    when I removed mine, I had to pull with the Bell attached, I imagine it can be done but I don't this it's an easy task.
    13 Durango R/T
    13 M6 Challenger R/T
    02 M5 Dakota QC Sport
    91 TKO 600 Dakota CC
    63 Dart 3 on da Tree
    May 2012
    Edmonton, Alberta
    Quote Originally Posted by DV8Performance View Post
    Hi All -
    TIA.
    Bellhousing is integral to the transmission so nope not possible
    Sent from my SM-G965W using Tapatalk
    Mar 2017
    Quote Originally Posted by Mopardoug View Post
    What?
    May 2012
    Edmonton, Alberta
    Quote Originally Posted by hotrod1 View Post
    What?
    Integral means the main case and bellhousing are all cast as one piece.
    Mar 2017
    Right but 6speed is not
    Dec 2014
    This isn't exactly true on the 6spd cars, as the OP has stated. One could remove the trans with the bell still on the motor, the problem comes in with installing the factory slave. The lines are metal and not flexible which makes the take next to impossible with bell in. It's much easier and faster to just pull the trans and bell together. Use a couple of long extension and a swivel for the upper bolts.
