Results 1 to 15 of 19
    Jan 2018
    First time at the strip with the new car
    Last night I finally made it to the track. Expecting the best outta the challenger. But I felt like I wasn’t getting good times. Beautiful weather last night at the track in Indy. The car is a 2012 Challenger SRT8 A5. With tb, cai, slp cat back, slicks, and a tune. Best I could get was a 12.61 at 111. That was leaving at idle. Every pass that I tired to leave at anything above idle the car felt sluggish off the line. My 60 foot times were horrible 2.0-2.1. My stick shift vette would do 1.8 all day. I’m just confused. Thought for sure this car was a low 12 sec car. Any info will be great. Do I need to put a stall converter in it? Here are the slips from last night. IMG_7162.JPG
    Jul 2007
    San Antonio, Tx
    You need to learn the car and how it reacts, comparing it to your vette is apples to oranges...
    2009 Challenger SRT8 TorRed (AKA Tori)
    SRT Max Plus cam, Ported n Polished intake manifold/Heads w/Long Tube Headers by Rich Mack, Edelbrock E-force supercharger, tune by Dave Katz, Cat delete, 3" exhaust w/Magnaflow mufflers 180* T-stat, catch can, Hurst short throw w/pistol grip shifter, Amsoil fluids
    06 Magnum R/T AWD
    1976 Corvette L82 (gave to my Son)
    Thanks 12str8 thanked for this post
    Jan 2018
    Quote Originally Posted by HemiSilva View Post
    Yea I’m trying I only got 6 passes last night. Launching an auto car is much different and something I’m not used too. Just didn’t know what is best in these cars.
    Jul 2007
    San Antonio, Tx
    Quote Originally Posted by 12str8 View Post
    I have the 6 speed and it seems that everytime I go to the track I add something prior so I'm still trying to figure mine out, it's all about learning how your car wants to launch. Just put a supercharger on mine so I know I have a ton to learn and hopefully don't break anything lol
    Jan 2018
    Damn I bet it’s going to fly! I’m not ready to spend that much money on it yet. Trying to get it low 12’s high 11’s. I was told that these cars can do it with minor mods. So trying to get there with out breaking the bank. Maybe a converter will help me. But then again I’m not sure this is my first auto car
    Mar 2017
    Bedford, Texas
    Try this next time you're at the track...
    Deep stage, hard on the brake, press the throttle to about 1200-1500 rpms, and when the last yellow light comes on let off the brake and roll on the throttle.
    You have drag radials, it'll feelike it's bogging, but your times will improve.
    My best in my Scat Pack Charger on street tires is only [email protected] 1.9 60' time
    Oct 2013
    It’s all in your 60ft times. What kind of slick are you running?
    Jan 2018
    Quote Originally Posted by ramryder77 View Post
    305/45/18 et street r
    May 2017
    As said above:
    Stage, hard on brake, rev the motor up to roughly 1500 ONLY once the ambers start coming down, on the last amber off brake and roll into the throttle (but to be honest you might be able to just mash the peddle since you have very minor mods and on DRs). OR you can just flash the converter once the last amber comes up (sitting at idle and then mash the gas).
    Start rear tire pressure at 20psi and work down as necessary for the track conditions. Bump fronts up to 40-45.
    Pull your spare/jack before going, 1/4 tank or less of gas.
    A converter will definitely help your 60’
    2013 Challenger R/T, 270 comp cam, BES p&p heads, OCPerformance dual plane, NX gemini plate, JBA longtubes, DSS one piece aluminum driveshaft, 88mm fastman throttle body, meizere electric water pump, 3.91 rear, lakewood drag shocks A2speed front coilovers...too much to list
    Likes 5DR HEMI, punisher69 liked this post
    Dec 2008
    NH
    Also, figuring out just how long to heat the tires in the burnout box will help. Too much heat will hurt you. Not enough will hurt you. Repetition is what it's all about....and practice. Good luck and have fun.
    Likes 6.1SilverFox, agoristmike, punisher69 liked this post
    Jan 2018
    Here’s a time slip from this Wednesday got a lot better times but trashed my radials. New ones on order along with a 3000 stall
    May 2017
    Wow 23mph! You are blazing through the trap!
    Haha just joking, solid improvement. How did you trash your radials? Too much burnout?
    Jan 2018
    Yea haha 23 I was excited and yea I think so. Belt is showing in both so I ordered new ones hopefully be here next week some time. Went to a 305/35/18 to see if that helps. Was told my old tires were to tall they were 305/45/18.
    May 2017
    At about 2 inches shorter, that will lower (numerically raise) your final drive ratio which should help with acceleration a bit. Look forward to seeing how it works out!
    Jul 2007
    San Antonio, Tx
    I'm far from an expert but I don't know why they told you the 305/45/18's were too tall, they are under 29" and you want some side wall to help with the grip. Look at the pro's, they have massive sidewall... Just a thought.
