CFM Performance
Results 1 to 8 of 8
    Jun 2015
    Longwood, FL
    CFM Performance billet baffled valve cover breather
    CFM Performance now makes it easy to vent the crankcase on your late model Hemi engine with our billet valve cover baffled breather kit. This kit is a direct replacement for your factory oil cap and allows unwanted crankcase pressure to exit.
    This breather is the ONLY one on the market which incorporates both a check ball to keep air from coming through while the crankcase is under vacuum along with an integral baffle. The proprietary baffle aids in keeping oil particles away from the breather. In other words, this breather acts just like a factory oil cap under normal driving conditions while allowing positive pressure to escape when present.
    The filter element is washable and we have numerous colors to choose from for the filter top. Although this kit was designed for use in racing applications, it works and looks great in any engine compartment.
    Take a look at our fitment range for the 5.7, 6.1, 6.4 liter engines in the Challenger, Charger, 300, Magnum, Jeep, and Ram. We will also have the 6.2 Hellcat breather available very soon.
    www.valvecoverbreathers.com
    Use discount code
    lxforums for 10% off for a limited time when ordering on our site
    Jun 2015
    Longwood, FL
    2014 Jeep 392 SRT
    Jun 2015
    Longwood, FL
    Procharged 6.1 liter Challenger
    Oct 2014
    Will the baffled design keep oil from spraying out?
    2014 HO SRT8 Core M6
    12.78 @110 PB N/A
    Version 3.0 in the works at MMPG
    Jun 2015
    Longwood, FL
    The baffle is designed to break up the oil from the air passing through. It always depends on how much crankcase pressure is being evacuated. We have not seen any issues of oil spraying out in our experience with the Hemi platform.
    Jun 2015
    Longwood, FL
    Looking for customer pics with our CFM Performance valve cover breather installed. If you own one then please please post pic or PM it to us so we can add to our product album. Click on the image below to view album. If you're on the album then feel free to tag yourself. Thanks in advance.
    Jun 2015
    Longwood, FL
    We have extended the discount code LXFORUMS which gives forum members 10% off. Save money on the best breather available for your HEMI!
    Jun 2015
    Longwood, FL
    Remember to use discount code LXFORUMS to receive 10% off your Hemi Valve Cover Breather order.
