Decided to let go of my Procharger p1sc to help fund another project.
This is a stage 2 kit, which means it runs on its own belt, the air filter faces forward instead of sitting on your hot valve cover like the other kit
It also has the larger race intercooler, and I've replaced the proflo surge valve with a much larger blow off valve similar to the red race valve.
These kits were sold for the 05-10 chargers only, and does not fit the 300 or magnum as is.
All piping was replaced, all 3" aluminum tubing, opposed to the powder coated steel and plastic that was provided with the kit.
intercooler brackets are modified, smaller aftermarket windshield washer tank provided as the charge pipe will route where the original tank is.
This kit will need some modification to your rad support, some trimming for better access to replace or clean the air filter periodically, and some trimming to the sheet metal underneath the stock airbox, which is necessary even with the original tubing for the stage 2 kit
Kit will include gauge pod that replaces sunglass holder, wideband o2 sensor and gauge, boost gauge. 60psi injectors, kenne bell BAP. Gates green belt.
the only thing I'm missing is the crank pinning kit, which can be borrowed, purchased or fabricated.
Asking $4000 I will document, photograph and organize all hardware on removal to give you clear instructions for install, the kit can be seen running and driving until a deposit is made.
More pics available upon request.
