Results 1 to 13 of 13
    Jan 2015
    Procharger p1, stage 2 kit, modified for Chrysler 300c
    Decided to let go of my Procharger p1sc to help fund another project.
    This is a stage 2 kit, which means it runs on its own belt, the air filter faces forward instead of sitting on your hot valve cover like the other kit
    It also has the larger race intercooler, and I've replaced the proflo surge valve with a much larger blow off valve similar to the red race valve.
    These kits were sold for the 05-10 chargers only, and does not fit the 300 or magnum as is.
    All piping was replaced, all 3" aluminum tubing, opposed to the powder coated steel and plastic that was provided with the kit.
    intercooler brackets are modified, smaller aftermarket windshield washer tank provided as the charge pipe will route where the original tank is.
    This kit will need some modification to your rad support, some trimming for better access to replace or clean the air filter periodically, and some trimming to the sheet metal underneath the stock airbox, which is necessary even with the original tubing for the stage 2 kit
    Kit will include gauge pod that replaces sunglass holder, wideband o2 sensor and gauge, boost gauge. 60psi injectors, kenne bell BAP. Gates green belt.
    the only thing I'm missing is the crank pinning kit, which can be borrowed, purchased or fabricated.
    Asking $4000 I will document, photograph and organize all hardware on removal to give you clear instructions for install, the kit can be seen running and driving until a deposit is made.
    More pics available upon request.
    Nov 2017
    Florida
    location?
    Jan 2015
    Brampton, Ontario
    Nov 2017
    Florida
    can u take 1 pic looking down into engine compartment. thanks
    Jan 2015
    Quote Originally Posted by Radiology6? View Post
    Thanks Radiology6? thanked for this post
    Likes Slickawd liked this post
    Corona, CA
    If it was originally for an 05-10 charger and you modified it for a 300C, do you still have all those components for the 05-10 charger?
    2006 Charger SRT8
    MPR Motorsports built 6.1 based/392 NA Stroker, BBK 85mm TB, TranZformer, Kooks Long Tubes
    Jan 2015
    Quote Originally Posted by netnathan View Post
    I don't think I kept the tubing but I will check on the weekend. The intercooler bracket on one side was cut off, I do have the other end but would have to be tig welded, however it should fit all cars the way it is set up now.
    Corona, CA
    Still for sale?
    Is this a P-1SC?
    Jan 2015
    Still for sale?
    Is this a P-1SC?
    Yes and yes
    Jan 2015
    Still available
    Jun 2018
    Alberta
    Sent you a message
    Jan 2015
    This is still available
    Aug 2014
    Edmonton
    What are the gains?
    2005 CHRYSLER 300C RWD​
    Edge 3200 Stall, 6.1 Intake, 6.1 Dampner, Taylor 8.5mm Wires, Jet 180 Thermostat, Tranzformer Kit With NOESP, BT EGR Block Off, BT Z Catch Can, SLP Loudmouth Exhaust, AFE Stage II Air Intake, Diablosport Trinity, Diablotoona 91 Tune, 3.06 SRT Differential, 216mm Non-Getrag Axles
    Demon Sequential Headlights, eBay Wing, LED Clear Corner Lights, Spyder Black Taillights, Chrome Pillar 6 Piece Covers, Chrome 20" Alcoa, Raised Cowl Hood
    Clarion NX404 Head Unit, Stinger Amplifier Kit, 2 Kicker 10" CVT Subwoofers, Kicker ZX750.1 Mono Amplifier, Boston Acoustics Premium
