BMR Suspension
Results 1 to 7 of 7
    Oct 2017
    Chassis Jacking Rails for 2008-2020 Challenger CJR110 - $289.95
    Add strong lift points and extra rigidity to your 2008-newer Challenger with bolt-on Chassis Jacking Rails (CJR110) from BMR Suspension. Jacking the car on the pinch welds can easily damage the pinch welds and floor pans, eventually causing panel misalignment. Built from heavy-duty 1 x 2-inch boxed tubing and 3/16-inch laser-cut, CNC-formed steel plate, BMR’s Chassis Jacking Rails are designed to give you a rock-solid jacking or jack stand point for your 2008-newer Challenger. BMR Suspension designed the bolt-on Chassis Jacking Rails for performance and street applications. These chassis jacking rails use existing boltholes and hardware, allowing for easy installation with simple hand tools. With BMR’s jacking rails, the entire side of the car can be easily jacked up from one jacking location. These jacking rails also add strength to the chassis by reducing flex. Installation time is about 1 hour. Proudly made in the U.S.A.!
    To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055 CJR110R_300dpi.jpg
    BMR Suspension
    813-986-9302
    Dec 2018
    Hamilton Ohio
    Hey. Was wanting to make a order. Do you have any coupon codes for us members to use. Thanks
    Oct 2017
    Use the coupon code FS6FS at check out on our website. It will save you 6% off most BMR parts plus get you free ground shipping in the lower 48 states. Let us know if you have any fitment questions on these parts.
    Dec 2018
    Hamilton Ohio
    Will the chassis jacking rails fit on a 2008 300c
    Sent from my motorola one 5G UW using Tapatalk
    Oct 2017
    No unfortunately they do not fit the Charger/300 platform as, the wheelbase is longer and the bolt holes are not in the same place.
    Frank Steadman
    Sales Tech
    BMR Suspension
    813-986-9302
    Jan 2016
    Do they make ones that fit Early Charger Magnum plat forms?
    Oct 2017
    No, sorry we do not currently, but I know it is on the R&D list. We are just backed up in R&D currently.
