BMR Suspensions Rear Cradle Bushing Lock Out Kit - SCB110
Reduce Wheelhop, bushing deflection, and cradle movement on your Challenger/Charger with a Cradle Bushing Lockout Kit from BMR Suspension. Built from billet aluminum, BMR’s SCB110 Cradle Bushing Lockout Kit is designed to greatly reduce cradle bushing deflection, which is one of the biggest causes of wheel hop. The upper inserts are CNC-machined and specifically designed to fill the voids in the factory bushings (front and rear). The kit is finished with billet aluminum cups that capture the bushing and prevent up and down movement. By filling the voids in the bushings, deflection is greatly reduced, allowing more power and torque to be transferred to the ground instead of being absorbed by the chassis.
We designed the SCB110 Cradle Bushing Lockout Kit for street performance, drag race, and handling applications. This bolt-on kit use existing boltholes and hardware, allowing for easy installation.
