*******************EDIT********************
Alpine has discontinued the joystick
RKJXT1F42001 is the replacement number now.
looks like you can buy 1 part here:
http://www.onlinecomponents.com/alps-electric_rkjxt1f42001.html?p=10114296
keep in mind the replacement is a 4-way not an 8-way. the 8-way was discontinued, probably because they kept breaking.
looks like they also have the 8-way but it's $50
http://www.onlinecomponents.com/alps-electric_rkjxt1e12001.html?p=10114295&pref=Repl
you can order a new plastic knob thing here:
DTR--- 1-800-373-3539 ...ext262...ask for katie
Ok.. first sorry the pictures are bad, all I had was my phone when I did this:
order the Joystick here: http://www.mouser.com/Search/Refine.aspx?Ntt=*RKJXT1E12001*&N=1323038&Ntx=mode%2bmatchall&Ns=P_SField&OriginalKeyword=RKJXT1E12001&Ntk=Mouser_Wildcards
Thank You Jaak for finding that...
Tools needed:
Desolder iron
empty can of some kind..
Solder iron
Solder
Jewelers Flat Blade Screw Driver
Jewelers Phillips Head Screw Driver
**basic soldering skills**
Step 1.
remove Nav unit from car. (if you struggle with this, then stops here DO NOT go further)
Step 2.
there are 4 screws on each side and 2 on the top and bottom of the face plate, remove these and pull off the Knobs (volume, tuning, Joystick)
(thank you Jaak for providing these pictures)
use small screw driver to top pop the tabs that hold the face plae on.
Step 3.
Remove the PCB board:
4 screws hold it in place:
remove the connector on the left side
Step 4.
place the unit on a mouse pad or some other type of anti-static pad.
I personally use an empty tissue box, because I can set the unit on it with the knobs inside the opening to prevent damage to them.
Step 5.
Desolder the old joystick, make sure you EMPTY the desolder iron after each pass (empty into the can) or you could spit hot solder onto the pcb board and Bye Bye Navi Unit.
this is a desoldering iron $25 at Radio Shack:
Step 5A
look at the difference in the 2 joysticks.. if the new one (shorter shaft) bugs you then you can do the following and swap out the shaft:
A. dissemble the old joystick:
use the flat blade screw driver to lift these four tabs:
open joystick:
remove the shaft:
repeat the steps for the new joystick and swap the shafts.
Step 6.
Now resolder the new stick in place:
If I recall there are 15 points to solder, the stick only goes in one way so you can't mess that up,, but BE CAREFUL not to bend the ends as you insert it, they break kinda easy.
Step 7.
finished:
Disclaimer
YOU DO THIS AT YOUR OWN RISK.. DON'T BLAME ME IF YOU SCREW UP YOUR UNIT.
Tools needed:
Desolder iron
Solder iron
Solder
Step 1.
Step 2.
Step 3.
Step 4.
Step 5.
Step 5A
open joystick:
remove the shaft:
Step 6.
Step 7.
finished:
Disclaimer
