Is there a solution to the MYGIG Lockpick no sound problem?
11K views 2 replies 2 participants last post by  Analog Kid
#1 ·
2005 Magnum RT
Upgraded to MYGIG RER radio using Coastal Tech Lockpick Pro adapter.
For the months after upgrade, I have put up with the common problem of no sound from the radio at start. Occurs in about 1 in 10 starts. Radio is on but there is no sound. Only fix is to completely switch off ignition and re-start. I read a suggestion once that it's caused by the audio amplifier not getting its signal to switch on.
Does anyone know if a permanent solution has been found?
I'm nearly ready to hardwire a reset button to power-cycle the Lockpick for when it happens.
#2 ·
I happens once-in-a-while on my MyGig with lock pick in my 2008 Magnum. All I need to do when there is no sound is turn off the head unit and back on. When it firs started I talked to Coastal Tec and Infotainment. They both told me they had never heard of this happening...
Good luck, and post what you find out.
