    Jan 2010
    Ontario, Canada
    Question Is there a solution to the MYGIG Lockpick no sound problem?
    2005 Magnum RT
    Upgraded to MYGIG RER radio using Coastal Tech Lockpick Pro adapter.
    For the months after upgrade, I have put up with the common problem of no sound from the radio at start. Occurs in about 1 in 10 starts. Radio is on but there is no sound. Only fix is to completely switch off ignition and re-start. I read a suggestion once that it's caused by the audio amplifier not getting its signal to switch on.
    Does anyone know if a permanent solution has been found?
    I'm nearly ready to hardwire a reset button to power-cycle the Lockpick for when it happens.
    2005 Magnum RT RWD
    Mar 2010
    Sedalia, Missouri
    I happens once-in-a-while on my MyGig with lock pick in my 2008 Magnum. All I need to do when there is no sound is turn off the head unit and back on. When it firs started I talked to Coastal Tec and Infotainment. They both told me they had never heard of this happening...
    Good luck, and post what you find out.
    Jan 2010
    Ontario, Canada
    I wish it was so easy.
