Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Nov 2010
    S. Jersey
    Quote Originally Posted by customaudioman View Post
    It’s alway best to set radio eq to 0db and the adjust amplifier gain next. Cross the the subwoofer over at 80hz (Lpf) on the amp. then adjust LC2I gain after that.
    Speakers for the dash, I use hybrid audio technologies Unity U3 wide-band 3.7” 4ohm Speakers. Frequency range 250 Hz -20k. They retail for $199.99 for the pair. Sound the best when amplified to get full potential out of them. I have the Unity U69 for the front doors (6x9). They cost $339.99 great midbass output.
    Sent from my iPad using Tapatalk
    Thanks for for the advice!! I'm going to make those adjustments tomorrow.
    As for the dash speakers, I'm hoping not to do another amp. Unless there's a small in line style amp I could use... I had one once on an alpine setup, was just like a 100w or something. I just want to avoid spending too much, and I really don't want to open the console up. My Charger dash was never the same after I took everything apart.
  2. #17
    Feb 2007
    Whoa, what year car do you have? I used to run a pair of HAT L3SEs up front in my old CTS-V..and loved them. I thought about adding a pair to my '16 Scatpack but didn't think they'd fit with their drop in depth..
    Pilot of a 2006 GMG Daytona Charger and a 2016 Jazz Blue Scatpack Charger
    ""We're in the pipe, 5 by 5""
  3. #18
    Feb 2018
    Can I ask what size tires are on your Challenger.
  4. #19
    May 2009
    Quote Originally Posted by jeeplaw View Post
    Mine is a 2011 RT had the 6 speaker Boston amplified system. Mounting depth on these U3 hybrid audio speakers are deeper then the L3SE drivers. They fit fine with adapters I made for them. I would upgrade the door 6x9 also to there U69 mid bass drivers.
    https://www
    .hinnantdesign.com
  5. #20
    May 2009
    Quote Originally Posted by 15SP View Post
    265/30ZR22 front
    295/25ZR22 rear
  6. #21
    Nov 2018
    Is anyone using the Toslink feature on their AmpPro Ch41? If so, did you still have to use RCA cables for channels 1-4 between the AmpPro and your amp and/or sound processor? I am going this route on my 2019 300S and will using the CH01 speaker wire harness as well to prevent hacking into the stock wiring. Any feedback on this would be greatly appreciated. The CH01 is supposed to incorporate the following features:
    • Works with PAC AmpPRO: AP4-CH21, AP4-CH31, and AP4-CH41
    • Can be used for other installations requiring plug-n-play speaker wire connections
    • Easily add amplifiers without cutting or modifying the vehicle’s original wiring
    • Provides a plug-n-play connection at the vehicle’s original amplifier location
    • Saves time by quickly utilizing the original speaker wires
    • Harness length 18 inches
