Results 1 to 11 of 11
    NW Ohio
    Track Prep for 2020 Charger 392 Scat Pack
    Hello All,
    I'm heading to the track (Mid Ohio Road Course) in my 3rd gen Charger 392 Scat Pack (2020). The car is mostly stock except for a CAI. I've driven the track previously in my 2nd gen (2012) SRT Charger. My previous track prep for the SRT consisted of:
    - Front adjustable control arm (increased camber)
    - Front Frozen rotors paired with front Hawk race pads
    - Replace stock brake fluid with Dot 5 high temp brake fluid
    - Nitto High Performance Tires (can't remember specific size & model)
    - Synthetic oil change
    With that track setup, my 2012 SRT performed exceptionally well at Mid Ohio. The brakes never once faded even with exceptionally hard driving. The coolant temp ran hot but would quickly cool off between sessions. The only issue I had was that I blew the Power Steering pump on the last session of the day. I've read that the 3rd gen LX's changed to electric power steering so the issue with the pumps doesn't exist anymore. Is that correct?
    I've also read that it's recommended to remove the under-engine panels to provide more engine compartment cooling. That sounds like a good idea and I'll probably do that.
    Any other thoughts or suggestions?
    RTaddiction
    Current Ride:
    2020 392 Charger Scat Pack
    Mods: 6 piston Brembos, LMI CAI
    Former Ride:
    2012 SRT8 Charger
    Mods: LMI CAI, Frozen Rotors, Intune, 180* T-stat, BT Catch Can
    Former Former Ride:
    2006 RT Charger - Black Crystal Pearl
    Mods: FRI Sidewinder Cam (!!), 6.1L springs, 6.1L rods, Diablo Predator w/ Custom B&G Tune, Kooks LT Headers & Hi-Flow Cats, Flowmaster Catback, RamAir Hood (Style I), AFE Stage II CAI, SRT Struts / Springs, 170* T-stat, Coolit Fan Mod, NoESP, BT Catch Can, Daytona Wheels, Daytona Hex Grill, Rear Spoiler, Nav In-Motion Disable
    May 2015
    Louisiana
    It says this in the Challenger OM and I assume this meant belly pans but some say no. Don't know what else it could mean. Does removing your grille really help? Seems to make no sense.
    Oct 2011
    PGH
    DOT 5 brake fluid!? That's the silicone stuff which is incompatible with other brake fluids. DOT 4 fluid with a dry boiling point over 600 is the norm - Catrol SRF, Motul, Wilwood, ATE, et cetera.
    Running with an HPDE group or TNiA? Other than watching for brake fade, your 2020 will have the fancy digital dash & pages to monitor all the important gauges - coolant temp, oil temp & psi, trans temp.
    I read the lower tier Mopars have all electric steering but some higher end ones retain electro-hydraulic systems (I may be wrong as I haven't paid too much attention to the LD/LA platforms). If it would blow again at least you know you can easily plumb in a larger heat sink cooler tube like from the Frankencooler thread to help things out.
    FURIOUS FUCHSIA 2010 Challenger R/T Classic A5
    WHOA RideTech coilovers, Hotchkis sways, PowerGrid endlinks, REM & Petty braces, CTP/BFNY bushings, AAD harness bar w/ Sabelt 6pts // SLOW SMF SRT 14.2 front & Pursuit BR9 13.8 rear rotors, Carbotech pads, Russell lines // FLOW LMI F-IV intake, Belanger Tri-Y headers, Zoomers catback, Joelvan's p/s pulley & dual-pass radiator, Russell p/s cooler // GO 215mm Wavetrac diff, AMG diff cooler & BlueTops, B&M pan, Tranzformer & NoESP // AERO 392 front clip // SHOW WebElectric, Hurst, Billet Tech, RiderGraphix, Performance Pedals
    Nov 2015
    Eastern NC
    Quote Originally Posted by TheFrankenberry View Post
    All the 392 cars have electric power steering. The Hellcats used the hydraulic, but think I remember reading something about the current ones having swapped to electric too. Slidd can confirm.
    Previous:
    '17 Camaro 2SS A8
    MPLS/STP - MN
    My suggestion is to run the car bone stock. Then you'll have a baseline for future modifications. In stock form, the car might surprise you.
    Click this link to see Photobucket images again!
    Follow White Ops R/T on Instagram, Twitter, and Facebook.
    May 2015
    Louisiana
    Yes true, from 15-up, all 392 cars will have electric power assist.
    In 18 and 19, Challengers Hellcats got it but it did not come to the Charger Hellcat until 20.
    Feb 2020
    Chicago burbs
    Quote Originally Posted by Slidd View Post
    It says this in the Challenger OM and I assume this meant belly pans but some say no. Don't know what else it could mean. Does removing your grille really help? Seems to make no sense.Sent from my SM-N960U using Tapatalk
    Removing the lower grill did make a tangible improvement on my oil temps. I also had this recommendation confirmed by Jim Wilder as being helpful.
    Feb 2020
    Chicago burbs
    Recommend changing pads and fluid before running on track...my stock pads went from 7mm to backing plate in ~30 mins. Powerstop "Trackday" pads were pretty good starting out. Motul/Castrol/Brembo/Endless fluid is ideal IMO. I've run 7 events with my car this year and the brakes are the biggest issue...even running Carbotechs now.
    May 2015
    Louisiana
    Quote Originally Posted by JAhmed View Post
    You have a Challenger? What year?
    Feb 2020
    Chicago burbs
    2020 Charger SP
    May 2015
    Louisiana
    2020 Charger SP
    OK thanks and I know Jim Wilder is the man. Track Prep for 2020 Charger 392 Scat Pack
