Results 1 to 13 of 13
    Jul 2009
    Cornelia Georgia
    NASA June Jam Video
    I finished 2nd in class
    Watch my race videos here--> https://vimeo.com/user1781792/videos
    Oct 2004
    Burlington, Ontario
    Great vid! congrats!
    If you had a bit more power on the long straight maybe you would have been 1st!
    2006 Magnum SRT8 "HEMIWAGN"; Hemiwagn2: 468 Aluminum N/A, BFNY built, AJ "Hemituner" designed and tuned. 9.495 @ 143.47 MPH, 1.361 60', 3215lbs with driver, DA-325ft.
    Hemiwagn1: 6.1 N/A recordholder, [email protected] MPH, 1.481 60', 3345lbs with driver, DA+500ft
    Nov 2006
    North Jersey
    Loved the video Joel, Thanks for sharing that , nice run through the esses as well, clip them apexes man!
    East Coast Road Racing Club https://www.facebook.com/groups/1377583362497085/ NA with a lot of suspension mods/SRT Max Plus Cam/Forged Push Rods/600HP Half Shafts/Magnaflow Hiflow Cats, Corsa Cat back/ Dave Weber Polished Ported Intake Manifold, HHP Installed Wavetrac/NASCAR Cooling Ducts to ET1970 3" Brake Plates/TI (Track) Backing Plates/ AERO Hood/Naturally Aspirated Force Flow Legmaker CF-F-III, Zygote Forgestar F-14's wrapped in Continental Extreme DW Tires, coming soon BFNY-Sublime NAG-1 modified with custom converter HemiTuner tweaked HHP DynoTune: Trinity 93 Octane 428 RWHP/408RWTQ
    May 2010
    ALABAMA
    Great video. You beat them in the corners but that long staight gets lets them catch up. You must smoke them on tracks with shorter straights.
    Jul 2009
    Cornelia Georgia
    I am still having issues with the engine Im not sure what to do next. If you listen closely you can hear the engine drop a cyl or 2 when im pulling hard and it kills me on the straights. The SCCA race 3 weeks ago the car ran great after putting a crank sensor in it ran perfect the whole race.
    This weekend It ran like it did before replacing the sensor right from the beginning listen to the difference of the sound of the Engine
    Jul 2009
    Cornelia Georgia
    I just sent in a sponsorship letter into Carbotech. I use their brake pads exclusively. if you watch my videos. I can out brake nearly every car going into turn 10. If they pick me up it will save me over 1k a season.
    After a race I have a lot of competitors come to my and ask what kind of brakes
    I have . I reply a completely Stock system with Carbotech pads .
    Their reply is usually like,
    (YOU ARE F---ING NUTS!!! I cannot believe you can go that deep in such big heavy car).
    Feb 2008
    Mechanicsville VA
    I use them too.....stock Brembos and XP12/10's. Last weekend I had a mustang guy in the passenger seat and after warming the tires I went in deep coming off the main stretch. His helmet went 1/2 way to the dash (full interior/seat belts). He busted out laughing and continued to do so throughout the session. His mustang is barely street legal as he's slowly turning it into a track car.......He was shocked my lap times were the same as his!!!!
    Quote Originally Posted by joelvan View Post
    (YOU ARE F---ING NUTS!!! I cannot believe you can go as deep in the big heavy car).
    Racing is like sex.........why would you want it to only last 10 seconds?????
    Road course session last 25-40 minutes each!!!!
    Alvin, Texas
    Awesome video bro. Makes me feel like I am driving instead of you.
    "DETONATOR"
    CT
    i have the same love for Carbotech pads. Pete showed me the light a few seasons ago after going way deeper than i ever could in brake zones. i never was able to make it up. Nothing like getting back all the ground lost in the straight in 1 brake zone.
    great drivin though in the first vid i watched. you seem much more composed and consistent than some of the previous vids. Looks like the car is really coming together and you are getting more comfortable with it as well. That engine power drop must be driving you mad, GL with finding a long term solution for it.
    Current mods: Hi-Flows, 180. Volant, PS Cooler, Trans Cooler, SS Brake Lines, B&B exhaust.
    Pedders Track II Extreme, Wavetrac, Moroso oil pan/catch can, 6.1 MTCM, Mopar trailer hitch.
    Puerto Rico
    Could it be the connector for the crank sensor? I've seen people use a zip tie to hold that plug good and snug. (another make) As far as Carbotech, another fan here. Instant bite and easy to modulate.
    Les
    Feb 2008
    Mechanicsville VA
    I'm slow.....I just realized/found the "like" button here. With all the advice you road racers have given me I need to start using that button!!!
    Joel, What compounds are you running (if you willing to share). I'm running XP12/10's front/rear and found I got 4 weekends out of the front set but the rear set look like they could last 10-12 more weekends (barely used). In an effort to get even better braking would running the 12's (or even the 16's) in the rear help distribute some of the braking power to the rear? I'm in a daily driver with a tuner, brakes/cooler and swap front pads/rotors and only rear pads (those rear rotors aren't getting much use either).
    May 2005
    Ottawa, On
    Thanks for the vid, Joel. Yep - power goes down on those straights. Hope you get it figured out.
    Man - you are really late on the corners! And the speed you are carrying through is quite impressive. Excellent driving.
    And - now I've gotta look into Carbotech pads . . .
    Patrick - Video: Racing in the Rain ........ Latest Mods..... 2015 Charger Hellcat has landed!
    "Racing is the best way to convert money into noise"
    Jul 2009
    Cornelia Georgia
    Quote Originally Posted by CT-MSRT View Post
    The reason im in better control is I am on 305 pirelli true slick instead of a 275 DOTslick I also have a new set of coilovers I was really over driving the car before to make up for lack of power and tires.
