Manton Pushrods
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Aug 2007
    Maryland
    Had a chance to get to the track this weekend. Went to Cecil Dragway. Can't say that I'm a fan there. Prep was meh, and the temp was 100, 60% humidity and the DA was 2600. The humidity plays a huge factor with our cars as the more water that is in the air, the less oxygen you can burn in your cylinders so you are kinda down a little bit in power. Things you learn as you go and listen to the elders at the track. I'm trying to up my YT editing game so I got RaceRender and am syncing it with my VCM Scanner data from HPTuners. Very cool tool and if you guys like it I'll buy the full version and start working on scripting in a Hellcat UI. I could be perhaps tempted to script in a ScatPack or custom UI for the right price (I work for beer or car parts or beer and car parts or beer while installing my car parts...).
    Let me know what you think, this will also be the last time I mount on the trunk, I think the roof is where it will be next.
    Hellcat PB > ET: 10.942, MPH: 125.66, 60': 1.636, R/T: .242
    Bone Stock Scat Pack PB > ET: 11.612, MPH: 119.52, 60': 1.634, R/T: .000 (gone but not forgotten).
    Likes PaulMc liked this post
  2. #17
    Jun 2020
    Great video! Assuming this is a A8, are you running in drive? Your shift points looked low.
    2016 scat A8
  3. #18
    Aug 2007
    Maryland
    Quote Originally Posted by Niner View Post
    In first gear the shift point is 5700 based on the stock PCM. That's the only gear that is short. The rest of the gears are at 6k which are the stock shift points. Went back again last night! Roof mounted 360 video > anything. Hope yall enjoy this short video.
  4. #19
    Aug 2007
    Maryland
    Had some fun at Cecil County on Saturday. The purpose was not to put a big E/T or trap at a huge MPH it was to learn how to launch the car as that is what I am struggling with the most. Unlike my Scat Pack I try to launch at 2k RPM with this thing power braking and always push through the brakes (I suck at the Memphis shuffle), after about the second run today I was heated to say the least. Time to adapt and overcome. I wanted to learn how to launch the car so I decided to spend some time with Launch Control (LC) as an alternative. I know a dreaded subject but today I did quite well with it and launched hard as hell at 2k RPM and had a great time, cutting good trees, and people were coming up to me after telling me my car sounded amazing on the line before launching. I'm going to keep an excel file of the times and log them after each event. I now have the dreaded task of backfilling and getting some sorts of metrics going. Here are that days entries.
    I am upgrading to the PowerStop pads as I think the stock ones are **** and I am also not ruling out that my converter might be on the fritz. Of note, the .585 R/T was because I got double bulbed by another test and tune driver and panicked and forgot that I don't need to worry and should just focus on myself. I got up to 2k, pushed through and then tried to get up on it but by then it was green already. It was at that point and after multiple F bombs I decided to spend the rest of the afternoon using LC. If I can keep my trees to sub .04, I'm ahead of the game. When the launch control is working, it's a nice treat for bracket racing and that's what I want to focus on. The technique and key to success for using LC is keeping in mind the 5 second timeout on the system. Only after both yellow bulbs on the second stage are lit do I mash the pedal to get it to come up (most trees are autostart). I started with 1500 on the .011 R/T, moved to 1750 on the .028 R/T and then moved to 2k on the .037 tree. Right now I'm getting the video into editing so stay tuned. I cooked my tablet (Race Render data) and go-pro in the heat.
