Manton Pushrods
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Mar 2016
    Quote Originally Posted by Alcharger View Post
    Since I own two ProStar pumps and mounts are on the chassis car, for now.
    Are you going to skip an inner cooler on Meth? IF/WHEN I go to boost, I want to skip the inner cooler...
    That depends. I’m going to try and keep it streak ends so I may run an a/w cooler with an ice box but if it goes to race only then I’ll ditch the cooler. The meth will do a fine job at keeping it safe.
    You may want to look Into a crankcase vac pump if you don’t run one already. I’m sure you’ll pick up some et and it’ll help with your oil.
    Likes Alcharger liked this post
  2. #17
    Birmingham, AL
    Yep, I have a vacuum pump on the crank case. It helps pull the meth out of the crank case after a pass and not contaminate the oil. You can see my vacuum pickup in the top of timing cover.
    Total Seal gapless rings are our standard at HRH Performance. These rings make more power than the others and work very nicely with Methanol fuel.
    ALL MOTOR Times:
    5.7L: 11.29 ET, 118.6 MPH, 1.50 60'
    6L: 10.76 ET, 125.6 MPH, 1.47 60
    7L:
    ALL MOTOR - Iron Block Record
    1st NA Iron Block in the 9's
    9.06 ET, 151.9 MPH, 1.28 60'
    Thanks: HRH Performance Engine, Thitek Heads, SGA Valve Body/Trans Brake
  3. #18
    Mar 2016
    Nice set up. Ild love to see a build thread or such.
  4. #19
    Birmingham, AL
    Thanks Matt,
    Seems that there is not much interest on LXF in a max effort NA engine.
    Besides some of this is proprietary...
    HRH Performance engines get the same detailed machining from mild to wild. The differences are in the parts like shelf pistons vs. custom.
  5. #20
    Birmingham, AL
    Hey, here is the For Sale link for WhiteLighnin on LXF.
    Own a legend, ultimate grudge car!
    9.0 Second 08 Charger, WHITELIGHNIN, Live Axle, 2930#s
  6. #21
    Dec 2014
    Nice car, shame that you are selling it and moving on. With that said, is your chassis car a Mopar? I thought I saw in the post Dart but I'm not sure. I'm assuming you are keeping the drive train for the chassis car? Whatever you decide please stay active, this is inspiring. I'm pissed that I missed you at the event in May, I was racing so didn't have much time to watch many other cars.
    13 Durango R/T
    13 M6 Challenger R/T
    02 M5 Dakota QC Sport
    91 TKO 600 Dakota CC
    63 Dart 3 on da Tree
