Manton Pushrods
Results 1 to 6 of 6
    Apr 2019
    Anyone using Lakewood drag shocks ?
    I’m interested in getting them but wanted to know if they are worth it and if they are bad on a daily driver .
    Jan 2005
    New Jersey
    I bought a set haven't installed them yet i hear there not to bad...mine are 70/30s with RT springs
    May 2017
    I had their 50/50 rears on my Challenger for a couple years, with front drag coilovers. When I pulled them to replace with Viking adjustable shocks, I found that they were failing (very loose rebound and compression) after less than two years daily driving and racing (~15k miles and maybe 30 passes).
    My 2 cents, spend a little more now and look into the Viking rears and A2speed’s 3 way adjustable front coilover option (that utilizes Viking shocks). They are works of art in performance and quality.
    Feb 2012
    Orland Park IL
    I had 50/50 rears and 70/30 up front with R/T springs. I was worried it would suck to drive daily, but it's fine. I believe it to have helped with launches as well, but I changed them in conjunction with a few other mods, so it's hard to say. The rears went out after two years and I went back to nivomats. my launches were considerably straighter with those with a comparable 60'.
    bill
    2007 BB Charger SRT8
    [email protected], 1.762 60' 620 DA
    Apr 2016
    Sunset Mesa, CA
    Recently installed Lakewood 50/50 rears and 70/30 fronts. Was worried about ride on the street but barely notice a difference. I actually like them better for highway cruising. They have definitely improved 60' and ET. I dropped three tenths ET adding the Lakewoods and 1 lb of boost.
    06 BB MSRT8 : Forged 393/2.9L Whipple w/ Stand-Alone 8-Rib Belt, 3" Pulley, 20 PSI/Cam & Heads/102mm TB/Ice Box/Fore Dual-Pump Fueling System, E85/1300cc Injectors/SHR War Viking/ProTorque TC - 3000 Stall/DSS Driveshaft & Axles/3.55 Wavetrac LSD/Mopar TCM/JBA Mids/Lakewoods - 50/50 Rear, 70/30 Front/Demon Killer Springs/Wilwood 15" brake conversion/Weld S71s - 15" beadlock rears, 17" fronts/Mickey Thompson ET Street R 275/60R15 rear, Sportsman S/R 28 x 6 - 17 front
    818 HP/784 TQ/10.101 @ 137.64 MPH
    Instagram : @fivedoorhemi
    Likes nightking392 liked this post
    Apr 2016
    Sunset Mesa, CA
    I want to tweak suspension further to improve 60' even more. Have the Lakewoods on with stock SRT8 front and rear springs at the moment.
    Anyone have any recommendations for other springs to try?
