Manton Pushrods
Results 1 to 6 of 6
Thread: driveshaft loop
    Nov 2018
    driveshaft loop
    I have a relatively stock 2006 Chrysler 300 SRT8 but I bought a set of 305/45-18 M/T et street r's because the 245/45-20's are a joke under 25 mph. Do I "need " to install one? I know it's a good idea
    Jan 2011
    Calabash, NC
    prob. not. i roasted my driveshaft but that was at 10 lbs of boost 600 hp. it was a stock driveshaft . i didn't have a loop at that time but no other damage.
    PB 0-60 3.24 MIR Raceway Drag Radials 6/18
    PB 60' 1.472 @ CF9 4/18
    PB ET 1/8 6.911 @ CF9 4/18
    PB MPH 1/8 101.32 @ The Rock 4/19
    PB ET 10.857 @ CF9 4/18
    PB MPH 127.29 @ Atco 11/18
    May 2017
    driveshaft loop
    Are you racing?
    Probably don’t NEED it on radials but it depends on hp/tq and if you are trying to get cleared by a track to run or running a stock driveshaft.
    It is cheap ($100-150) insurance though.
    Aug 2007
    Santa Clarita
    No, you don't need a driveshaft loop yet. While in general they're a good safety item, the SRT8 driveshaft is stout and so are the joints. What you're much more likely to need are stronger axles, on a 2006 they're the weakest link in the whole drivetrain.
    MoparMax.com
    2007 MSRT8 Arrington 426 ci|Magnuson Supercharger|Hedman Long Tubes|978 hp 866 lb ft
    DSS 9" rear, axles & CF driveshaft|Strange 3rd member 3.89
    5400 stall |Westminster Transmission TH400|LAT OIL & ATF
    Diablosport Trinity|Mickey Thompson|RPM Rollbar
    9.71 @139 mph
    NHRA PSCA SCEDA
    2012 & 2014 PSCA Street Muscle Championship Runner Up
    Corona, CA
    ^ Yep....no driveshaft loop required, but you will need stronger axles. Although....usually.... the axles only break when you go to slicks.
    2006 Charger SRT8
    MPR Motorsports built 6.1 based/392 NA Stroker, BBK 85mm TB, TranZformer, Kooks Long Tubes
    Apr 2016
    Sunset Mesa, CA
    ^^Although, I believe, if you run true slicks - as opposed to DOT drag radials - a drive shaft loop is required to pass tech, regardless of year or HP. Although it is up to the individual track/inspector whether they enforce that rule.
    06 BB MSRT8 : Forged 393/2.9L Whipple w/ Stand-Alone 8-Rib Belt, 3" Pulley, 20 PSI/Cam & Heads/102mm TB/Ice Box/Fore Dual-Pump Fueling System, E85/1300cc Injectors/SHR War Viking/ProTorque TC - 3000 Stall/DSS Driveshaft & Axles/3.55 Wavetrac LSD/Mopar TCM/JBA Mids/Lakewoods - 50/50 Rear, 70/30 Front/Demon Killer Springs/Wilwood 15" brake conversion/Weld S71s - 15" beadlock rears, 17" fronts/Mickey Thompson ET Street R 275/60R15 rear, Sportsman S/R 28 x 6 - 17 front
    818 HP/784 TQ/10.101 @ 137.64 MPH
    Instagram : @fivedoorhemi
