Manton Pushrods
Results 1 to 8 of 8
    Jun 2012
    Greater Detroit, MI
    Track/Street Setup front/rear tire height variance
    Anyone happen to know what the max height varaince between front and back before throwing a code? I have encountered it but was curious how certain people run like 28" front and 29" or 30" rear.
    Aug 2018
    Oklahoma
    also note, what gear do you have and what RPM do you want to cross at?
    2018 Indigo Blue 392 Daytona
    Calgary, Alberta
    Because you have neglected to state year / model, the following is a shot in the dark...
    Rotational velocity is monitored real-time. ABS must be disabled in order to operate without setting a DTC. Disabling ABS reporting of the four wheels velocity to the FCM can be defeated by temporarily removing B+ to the Dynamics Sensor Module (3-axis gyro).
    Then there's ESP / Track modes...
    May 2017
    I have ran 28” fronts and 29-30” rears routinely, street and strip, on my 13’ Challenger with no codes or warning lights.
    Aug 2016
    I have run <27”(245/45/18)up front with >29”(305/44/18) in the rears without throwing any codes for abs or esc. I was certain it would throw a code , but It didn’t.
    As far as the track , Haven’t run skinnies yet , but I do have 18’s with a 255/55(29.04”) up front and a 305/45(28.8”)in back. With that setup and 3.70 I crossed @ ~64-6500 , with the 3.09 it’s @ ~58-5900 give or take. I went back to 3.09 for the stock 392 , but I may go to 3.70 depending how the new 426 feels with the cam. Hopefully find that out soon
    Likes kyle_91 liked this post
    Jun 2012
    Greater Detroit, MI
    Car is a 07 Charger with a 3.09 zf diff with a scat cradle.
    Current tire out back is a 315/50/17. It's a twin turbo 426 build and will be making 1000+.
    Mar 2017
    How do those tires fit on your car. Can you post a pic. Those are the exact tire I want to run on my challenger.
    Jun 2012
    Greater Detroit, MI
    Quote Originally Posted by hotrod1 View Post
    These are the 17x9.5 race stars. I had to cut out a bunch of the inner fender liner and then there are some thick sheet steel behind it with ribbing that I had to take BFH to and beat the crap out of it.
