Results 16 to 30 of 32
  1. #16
    Nov 2016
    Well I know enough to know you know a great deal of these engines. That said, while not with hemis I have seen intake seats drop out because the head got hot, and the cool fuel coming in past the intake seat keeps it cool and when there is not a lot of press, the seat falls out.
    Tom
    Sent from my SM-G975F using Tapatalk
  2. #17
    Nov 2016
    My above message was for Hemissary
  3. #18
    Calgary, Alberta
    Quote Originally Posted by TomStark View Post
    Tom
    I appreciate the compliment, thanks.
    This is one of those things that the internet has emotionally latched onto and has developed legs of it's own (the act of reducing anxiety about valve seat failures :^)
  4. #19
    Nov 2011
    Ontario,Canada
    Well my car is stock right now, so I'm probably better off with the stock temp thermostat I guess...
  5. #20
    Mar 2016
    N. GA
    Watch out for Hemissary, he's a pretty accurate sharp shooter.
    2013 Dodge Charger R/T Plus, Edelbrock E-Force 2300TVS 6.8 PSI, 450hp/459tq, Corsa CatBack, 3.06 Open Diff, Severe Duty Radiator, Dual Fans, OE Oil Cooler, Pursuit BR9 Brakes.
    Likes blue_devil liked this post
  6. #21
    Nov 2011
    Ontario,Canada
    Finally got a call that the water pump is in!
    I need to decide tonight (so I can order it in time) whether to get an OEM Mopar (203* T-stat $46.43CDN!!! or 2x as much from the dealer!!!) or a Stant 48799 (190* Superstat $12.28), or a Stant 46792 (203* Superstat $12.25) :(
  7. #22
    Calgary, Alberta
    Quote Originally Posted by IcarusLSC View Post
    If you're not going to alter fan on-temperature set points, stick with the 203F T-stat.
  8. #23
    Nov 2011
    Ontario,Canada
    So do you think I should go with the Mopar or Stant Superstat then?
    Thanks
  9. #24
    Calgary, Alberta
    Thanks
    Stant would be fine; just ensure it is identical structure-wise to the OEM. That is to say, there is a backside extension / plate that redirects flow to warm the engine up quicker.
  10. #25
    Oct 2011
    PGH
    I've been running a Stant SuperStat for 5 years now without issue. Can't say the same for Jet (didn't open at the proper temp during the boil test) and Motorad (was damaged out of the box). And Hemissary's correct, if you're not adjusting the fan settings via a tuning device then just stick with the stock 203F temp.
    FURIOUS FUCHSIA 2010 Challenger R/T Classic A5
    Mopar // SRT // Pursuit // LMI // Zoomers // Belanger // Diablosport // Hotchkis // PowerGrid Inc // REM // Petty's Garage // AAD // Syncro Design Works // Ridetech // Crank This! Performance-BFNY // Serious Metal Fab // Carbotech // Russell // Sabelt // Rennline // Joelvan // ATI Perf // Earl's // Improved Racing // B&M // AMG // Wavetrac // ZAutoTech // Saleen SMS // Speedhut // Black Cat Custom // WebElectric // Hurst
  11. #26
    Nov 2011
    Ontario,Canada
    k, I'll order a Stant Superstat for now. Thanks guys
    I almost fell over when the dealer called me and said the OEM stat was $91 CDN lol...
  12. #27
    Mar 2016
    N. GA
    I really like the superstat. Where I see it differ is it doesn't cycle alot.
  13. #28
    Nov 2011
    Ontario,Canada
    Its in the dealer getting the water pump done finally. Sent it with a stock temp Superstat for them to put in too...
  14. #29
    Dec 2018
    Chicago
    A T-stat with a lower set point will not be of any assistance as it relates to valve seat failure; this is because the thermal energy - right at the valve seat / cylinder head interface - is unaffected by coolant temperature.
    This hurts to read... I was hoping to kill two, maybe 3 birds with a new coolant setup, LOL! I did a major, time consuming flush of my entire system last summer and yes, typical crap came out of the 107K motor. Upgraded SRT radiator & hoses, regular RT hoses in the back, DORMAN 620039XD fan, 190 T-stat. My Magnum still hits 225 degrees when idling and stop and go traffic now and then, when ambient temps are above 60. I've been monitoring the dash for months, just to see how the new system is working. I'm ready to get the car tuned, so it peaks at 203 only. I'll buy a new fan and install it if my new one prematurely craps out.
    So I'm on RockAuto, seems like they have plenty of WP available. I went with a GMB last spring and it's still sitting in the box, my OEM spins just fine and the corrosion around the T-stat area was minimal.
    Do I have a Gen 1 or Gen 2 WP from 2006? Why do I ask, because I believe my WP has a drip from the backside, not the shaft area or T-stat area. I think the gasket is bad and RA has two variations available.
    2006 (Manu.Date 5/05) Magnum RT (midnight blue) - STOCK... Rolled over 100K on the OD. Just general maintenance for now.
  15. #30
    Calgary, Alberta
    Quote Originally Posted by blue_devil View Post
    Only one type of 5.7 / 6.1 water pump in 2006 model year.
