Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Nov 2016
    I looked at the link and it is for your 6.4 manifold on your 6.4, just gives you control, does not appear to integrate it into a 5.7
    Sent from my SM-G975F using Tapatalk
  2. #17
    Dec 2012
    Ajax Ontario Canada
    Richard Holdener on youtube has alot of great dyno tests. He does the stack injection on the gen3 hemi as well. I know engine masters did a plenum volume test which Richard has a video of the giant plenum test.
    STACK ATTACK!! DIY ADJ HEMI INTAKE - YouTube
    MEGALODON + KEG=KEGALODON! - YouTube
    I kept my 6.1 with the stock intake instead of going carb because of the better low and mid range power. I have thought about using the truck 6.4 intake on it. I think it will fit the non vvt block and it also points the throttle body in the right direction for my setup.
  3. #18
    Mar 2010
    Atlanta
    Quote Originally Posted by TomStark View Post
    That link is misleading...it is for the 5.7L as I know someone who used it for that purpose and he reported plug and play.
    Besides...does it make any sense that a 6.4L owner would need such a harness?
  4. #19
    Nov 2017
    Quote Originally Posted by Chase300 View Post
    I thought Z-Automotive came out with a plug and play harness for installing the SRV 6.4 manifold on the 5.7???
    Here it is;
    6.4L HEMI Intake Manifold Short Runner Valve Controller by Z-Automotive
    I have one, and it works great. Joe is a friend, and sent me one to test while MMX was dyno testing. I had the old setup with the MSD box, and this is much better, and easier. Install time was about an hour.
  5. #20
    Nov 2017
    Adjustable thru the cluster and steering wheel
    Sent from my Pixel 3 using Tapatalk
