Results 1 to 15 of 22
Thread: New key
    Nov 2019
    New key
    05 magnum rt....my buddy at dealership quoted me 275 for a key cut and programmed. Is there a cheaper way like eBay key etc?
    Sent from my GM1915 using Tapatalk
    May 2016
    Calgary,AB
    Quote Originally Posted by sin.hemi57 View Post
    There are certain locksmiths that will cut the chipped key and re program it. Might be a little cheaper then the dealer, worth a call around.
    Nov 2017
    Nov 2017
    Quote Originally Posted by KYUUBI View Post
    This may help. I have not had a chance to test it.
    Nov 2019
    Thanks! Just gotta find a key online and someone to cut it
    Calgary, Alberta
    Bought units online, ensured they could be recognized / programmed using existing OEM keys / SKREEM system, then had Home Depot or a Lock Shop cut them. If they didn't communicate, they were returned.
    Feb 2018
    NorCal
    Keep in mind that some cars that were subject to the ignition switch recall P57 (August 2015) can no longer be owner programmed.
    Nov 2019
    Quote Originally Posted by Root66 View Post
    Anywhere I can check to see if this one had the recall?
    Calgary, Alberta
    Not applicable to 05' platforms.
    Nov 2019
    So I gotta go to dealer?
    Calgary, Alberta
    No; the TSB does not apply to your model year. If memory serves the key identification process is called out in the Owner's Manual. You will require two (existing) valid / functioning keys in order to marry up to six more.
    Nov 2019
    Gotcha, it only came with one though :(
    Calgary, Alberta
    Then you'll need to have a Dealership use a scan tool.
    Nov 2019
    Damn, I guess I'll have to bite the bullet. Thanks!
    Aug 2009
    Just saw this. Two keys from ebay for $12. Programmed the keys via Appcar. Had them cut at Walmart. I have two brand new keys for less than $15.
    05 Magnum AWD SXT Hemi Swap
    instagram.com/hemisxt
