Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: New key
  1. #16
    Calgary, Alberta
    Just saw this. Two keys from ebay for $12. Programmed the keys via Appcar. Had them cut at Walmart. I have two brand new keys for less than $15.
    Great idea; can you point folks to the seller / keys?
  2. #17
    Nov 2013
    South Florida
    Nice, I could not get either the ebay or oem keys to work with the Appcar feature.
    2006 300c SRT8
    PWR Ported Heads | HHP Stage 2R Cam | 3.91 Getrag | GTP Ported Intake Manifold | Kooks Longtubes | Corsa Sport / SRT Resonators | AMG 8 Piston Brake Calipers | Hemituner 6,800 TCM | BT Catch Can | LMI True CAI V2 | Tranzformer | MM 87mm TB | Johan Tuned | REM Adjustable Endlinks & Front/Rear Shock Braces | 33/22mm Front/Rear Sway Bars | Michelin Pilot Sport 4S 305/35/20 & 275/40/20 | 10" Widened Oem Wheels | LC-2 Wideband Analog Output to Trinity | Mishimoto Full Aluminum Radiator
  3. #18
    Calgary, Alberta
    Quote Originally Posted by BM_SRT View Post
    Agreed; I too have had hit-and-miss with online MOPAR keys. Thankfully they can be returned. Hence the value in knowing this specific Seller...
  4. #19
    Nov 2013
    South Florida
    That's what I figured but I ordered an OEM Mopar key as well with no luck.
  5. #20
    Aug 2009
    New key
    I was shocked they came with the internals. I bought them thinking it was just the shell. I programmed one to my 05 Magnum and one to the 13 Avenger for backup keys. Appcar worked perfectly. Here is the seller
    05 Magnum AWD SXT Hemi Swap
    instagram.com/hemisxt
    Thanks Hemissary thanked for this post
  6. #21
    Nov 2019
    Ordered a set. What is appcar?
    Sent from my GM1915 using Tapatalk
  7. #22
    Feb 2018
    Boca Raton, fl
    Like to know also. which one?Appcar DiagFCA – diagnostic tool – Jeep, Chrysler, Dodge, Ram
    Recomended interfaces:
    • OBDLink LX / MX bluetooth
    • OBDLink SX USB
    • Vgate iCar2 bluetooth
    2013 Chrysler 300S, Stock 6.4 BGE with 6.4 SRT cam, AIT 18% OD pulley, E-force 2.62 pulley(12.2 lbs boost), fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, 3" Magnaflow Cat-back, FTI 2800 stall, Trans by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. aluminum rad. SRT fans. Brembo upgrade. Stage one MOPAR springs, XIX X39 22x9 +15 - 22x10.5 +22 with NITTO NT555 265/35R22 - 295/30R22 going in: TSP boosted Stage 4 226/235 582/582 117+4
