Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Mar 2016
    Quote Originally Posted by Montreal300 View Post
    Is the fuel pump still running? It should stop after a few second once the system pressure has built up. If it still runs then the pump is proably toast.
    That will cause a no crank?
  2. #17
    Aug 2019
    That’s what I was thinking
  3. #18
    Sep 2009
    Bainsville Ontario
    Probably. Injectors need a certain pressure to function properly and in open loop (starting), the computer has no feed back from the O2 sensors so pressure insures adequate flow from the injectors.
  4. #19
    Aug 2019
    So without the fuel getting up to pressure, that wouldn’t let the car crank/turn over at all?
  5. #20
    Mar 2016
    I can see that causing a no start, But not a no crank.
