Results 1 to 7 of 7
    Nov 2014
    What’s this plug?
    It’s been a long time since I took this engine apart. Getting ready to put it back together, I noticed this plug, I can’t seem to remember what plugs in here
    It’s on the drivers side back of the engine by the front o2 sensor plug.
    Anyone tell me?
    Nov 2014
    Mds?
    Likes BlackAce liked this post
    Oct 2011
    South Jersey
    What’s this plug?
    I’d have to agree with the you. Straighten out the harness. Lay it out on top the motor where the injectors go over and place the connectors where they belong. If it’s a short wire towards the back of the of the motor then it’ll be the MDS connector.
    2006 Dodge Charger R/T - 85mm Throttle Body, AFE Stage 2 CAI, 6.1 Intake Manifold, Modern Muscle Intake Adapters, 219/223 cam, 6.1 pushrods, Manley NEXTEK Valve Springs, 6.1 Timing Chain, 6.1 oil pump, Edelbrock Titech Headers, Flowmasters X pipe, Thrush 2 Chamber Mufflers, Flowmaster Resonators and tailpipes, 3200 Edge Converter, Mopar TCM, Tranzformer, Carbon Fiber Pistol Grip Shifter, 3.06, Brake Performance drilled and slotted rotors.
    Old Hickory, TN
    Nov 2014
    It s not MDS
    You sure? It’s the only part I don’t have, it’s been deleted, iirc the mds plug clips to the back of the head correct?
    Oct 2011
    South Jersey
    Quote Originally Posted by BradJo9 View Post
    Next to the driver’s side head under the intake manifold.
    Nov 2014
    Correct, the drivers head that’s where this plug is. Pretty sure the mds harness plugs in to this.
