Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    Sep 2018
    Ohio
    Help with engine surge/stalling
    So I’ve done a ton of research and there are soo many things to fail or need replaced, so looking for some help.
    The Problem:
    I have to give it a little gas right after cranking for it to stay running, or the rpms will go up then back down and shut it off. After starting its fine at idle, until it will sometimes jerk or take 5-6 second to shift when I change gears. Also, I have to come to a stop slowly or it will drop the rpms again and die.
    I have already replaced, fixed, gotten rid of:
    -EGR
    -MDS
    -Cam Position Sensor
    -Air Filter
    -PCV Valve
    -Cleaned the throttle body
    Oct 2018
    What year? It could possibly be related to the gas tank recall for the early years of the lx family
    Likes md20twenty liked this post
    Sep 2018
    Ohio
    Update:
    I have been reading about the IAC, but mine is in the throttle body and doesnt look like it can be removed/cleaned. Do I have to replace the throttle body to replace the IAC?
    Sep 2018
    Ohio
    Sorry, it’s a 2005 Chrysler 300C. Has upgraded cam and supporting items if that helps.
    Oct 2018
    My 06 Magnum was doing similar things before I had the dealership replace the tank under the recall. It’s worth checking out if you haven’t
    May 2014
    Fayetteville, NC
    Once again, it is not a recall. It is a lifetime warranty.
    2005 Cool Vanilla Magnum R/T
    20" 2008 SRT Alcoa wheels
    Front SRT shocks/springs
    245/45/20 Firestone Wide Oval, Front Brembo Conversion
    K&N CAI, Diablosport InTune
    MSD Blaster Coil Kit, 6 Disc RAQ Radio
    Thanks AnglerRT thanked for this post
    Likes AnglerRT liked this post
    Oct 2018
    Quote Originally Posted by classicr View Post
    You are correct
    Sep 2018
    SF Bay Area
    If the engine problems occur with a full tank, I would definitely get the tank replaced. At the very least it's a free fix that can help rule out one other possible problem.
    Likes md20twenty, AnglerRT liked this post
    Jul 2004
    City of Trees
    Have you put a good computerized scanner on it to see what's going on? Did this begin shortly after installing the cam? Have you done a tune on it since installing the cam? What RPM are you trying to idle it at? As I recall, your cam was slightly more radical than "mild" and may need a tune or, at a minimum, just an idle adjustment to work properly. I've run both my somewhat modded 5.7's with the stock tunes and they run quite poorly with it. If you haven't yet, IMO, you should also do a little tweaking to the transmission. If I had left either of mine totally stock, I would have had to put a new transmission in long ago.
    I just recently mild cammed my SRT8 and am still running the stock tune and stock transmission settings on it. It seems to work fine but, because it's kind of a "factory hot rod" it's set up pretty well from the factory and probably won't need a special tune unless I start doing a bunch of other stuff to it and/or want a little more power. The cams in all 3 of my Hemi's are more low end oriented than lots more power on the top end. I don't run mine at 6000 RPM a whole lot (well still more than I should), so I opted for better low/mid range cams.
    06 300CSRT8, Comp cammed, 85mm TB, HP/DS Tuners, 06 Jeep GCO and 05 Magnum RT (5.7's) both modded almost the same, MDS "ON" Lt, Fumoto Drain Valves, BT Catch Cans, SRT8 CAIs, AFE Filters, Sonnax Trans Line Press Booster, SC, DS and HP Tuners, Transgo Shift Kit, ARH Long Tube Hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvrs, SRT8 frt/rear bumpers, FRI Sidewinder Cams advanced (Jeep 6*/Maggie 10*), 6.1 valvetrain, SLP 25% UD Pulley, BBK and Arrington 90mm T-Bodies, SOS Ign Coils,TEA ported/milled heads w/new valve seats, SRT Reps.
    Sep 2018
    Ohio
    Yeah I have an intune i3 and it doesnt throw any codes, that's the weird part. It did start happening after the cam, but ever since then, I've been working with my tuner to get it figured out. I have Jay Greene (Greene Racing) tuning it, but we cant figure out whats causing it and its getting a but frustrating after a month of surging. We are trying to get the good sounding idle, in the low 700's, nothing crazy.I also haven't done anything to the trans, I haven't modified a single thing on my end other than the fans come on earlier to keep it cooler.
    Sep 2018
    Ohio
    I’ve been doing some reading.. thoughts on if its the fuel filter? How difficult would it be to change, or would I have to replace the whole pump??
    May 2017
    Quote Originally Posted by Mandrow7 View Post
    As far as I am aware, the filters are all integrated as part of the pump i.e. not serviceable.
    Jul 2004
    City of Trees
    This is not a high end diagnostic scanner and probably won't give you all the information you need to verify the integrity of the various engine management readouts and modules. A few of the things you'll need to monitor and evaluate are, short and long term fuel trims, timing, oxygen sensor readings at idle and cruise, fuel flow rate, crank/cam position synchronization, etc. A fuel pressure readout would also be handy to have. Results of these things should help point you to, and/or eliminate some of the engine management components as the culprit(s).
    Jul 2004
    City of Trees
    Update:
    Yes, the IAC "feature" (there really isn't one, per se) is built into the 5.7/6.1's throttle bodies. I wouldn't go changing it right away either, especially if you haven't messed with it and it was working fine before the cam change. It's also easy, again with a higher end diagnostic scanner, to verify proper follower (pedal to TB) operation and do a throttle reset/relearn, if needed. If it needs cleaning, be VERY careful, as it's easy to screw up the electronics and then, for sure, you'll need a new one. I haven't checked, but there is probably a thread somewhere on this forum that will tell the best way to clean the 5.7/6.1 throttle body.
    Jul 2008
    Hughesville, MD
    Could be a bent valve , or a leaking intake manifold, both won’t always pops codes.
    seen this first hand on many 5.7/6.1s with cam upgrades
    2017 Ram 3500 Cummins Laramie
    2019 Challenger Scatpack Widebody
    2008 Charger R/T sold CAM ONLY RECORD HOLDER 12.34 @108.89 & 1.66 60'
    Email mailed tuned by [email protected]Comp268cam,
