Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    Nov 2018
    Elephant Butte, New Mexico
    Sent this message to The Cylinderhead shop:
    " Will be needing a set of heads for my '05 Magnum 5.7 soon. Do you replace "all" valve seats, intake and exhaust, or just those that are bad? Do you paint the rocker area of the head?"
    This is the reply I received:
    "Hi,
    We install all new valve seats as stated in our ads, all 8 seats.
    We do spray a product called alumi blast on our aluminum heads after they are machined and before assembly. It is not considered a paint but it is a spray. It is mostly a protectant and to keep smudging down during assembly.
    If you do not want them coated at all that is no a problem as long as you request that.
    Let us know if you have any other questions.
    Thanks, Tim"
  2. #17
    Calgary, Alberta
    Quote Originally Posted by TLH101 View Post
    "Hi,
    Thanks, Tim"
    All eight? Hopefully its not seven or nine
    Smudging? WTF is smudging? It would appear that is the same thing as "aesthetically pleasing".
    Are they talking about women and makeup?
    Alumi Blast
    BTW, just the intakes will be fine.
