Results 1 to 11 of 11
    Jul 2016
    Pre eagle 5.7 truck heads
    That come without egr. Can I use these to build a spare set for an 06 magnum rt? It just requires some tuning?
    Mar 2016
    I have a set of car 5.7 heads for sale if your looking
    May 2010
    MD
    Pre-eagle no EGR, you either have 03 1500 heads or 03-08 2500/3500 heads. Either delete EGR (if you haven't already) or open up the EGR port on the head.
    03 Hemi Ram, 05 Magnum R/T, 06 Charger R/T (RIP)
    Calgary, Alberta
    Yes you can. You need to be able to delete EGR functionality within the tune or accept the DTC that would be (permanently) set.
    Jul 2016
    Same car....how about this?
    Eagle intake-eagle heads-stock eagle manifolds-my current JBA awd mids?
    If the stock eagle exhaust manifold will bolt to my current mids, that would save me a lot of trouble
    Dec 2016
    Charlotte NC
    You can work around the non EGR truck heads with either doing an EGR delete or doing a little drilling you may be missing one drilled and threaded hole for the EGR valve as well. You will need to make sure the drivers side head is tapped for the power steering pump bolts as well. Otherwise they are the same castings as heads used on pre Eagle cars.
    May 2010
    MD
    Quote Originally Posted by Trump_Rises View Post
    Sounds like a recipe for fun, they should work, the eagle exhaust manifolds are shaped a bit different but not so much that you couldn't make them work. Hopefully you're gonna cam it if you're gonna go through all that work though.
    Jul 2016
    No cam. That 35 hp average gain isnt worth the cost of cam, spring, pushrod plus tuning.
    However. The E50 I can get with the bigger injectors is.
    Jan 2017
    the Eagle Intake hits the back of the "widows peak" on the pre eagle 5.7 block.
    Mar 2016
    Quote Originally Posted by ric3xrt View Post
    i believe they make spacers for that issue.
    Thanks ric3xrt thanked for this post
    Likes ric3xrt liked this post
    Jan 2017
    Yes there are spacers out there for it, just like old 5.7 heads to 6.1, just don't want to see him try and bolt them down and have a WTF moment
    Likes DBL.DWN liked this post
