Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 47
  1. #16
    Calgary, Alberta
    If memory serves, I don't believe the transfer tube running across the top on the OEM RT fuel rail system offers enough clearance over the aluminum manifold. There should be plenty of folks around willing to give away theirs.
  2. #17
    May 2014
    Virginia Beach, VA
    But what about the 6.4 SRV manifold?
    Sent from my SAMSUNG-SM-N900A using Scat Pack Forums mobile app
    2006 Dodge Charger Daytona TorRed #1354, SRT Heads/Intake - ARH Long Tubes - Spartan Plus Cam - Magnaflow - 3.91s - 411rwhp/410rwtq
    Acceleration video: https://www.youtube.com/watch?v=MLey...aubWU9N6ezVy7g
    I detail cars in the Virginia Beach/Norfolk area! 757-435-4027
  3. #18
    Calgary, Alberta
    Ah, duh, don't know, never tried.
  4. #19
    Jan 2017
    6.4 Intake hits the back of the "widow's peak" on the 03-08 5.7 and the 6.1 block. the Eagle 5.7 and 6.2/6.4 blocks have a recess there at the top of the peak to clear the front of the manifold.I have to check it again but you'll need a .040 thick head gasket to have enough clearance for the 6.1 heads, the .030ish 5.7 gasket won't give you enough Piston to head clearance.
    Thanks Beach Goat thanked for this post
  5. #20
    May 2014
    Virginia Beach, VA
    Update
    Ended up at 11:1 compression with the 6.1 heads and stock 5.7 head gasket. No issues, no knock retard, motor loves it.
  6. #21
    Apr 2016
    Quote Originally Posted by Beach Goat View Post
    Update
    so what combo did you end up going with? 6.1 heads, 6.4intake and your 5.7 block? Any other work you did. I'm very interested in this.
  7. #22
    May 2014
    Virginia Beach, VA
    I ended up using a 6.1 intake, but the full build was:
    5.7 hemi, stock
    6.1.heads, stock, milled 0.003"
    6.1 manifold, stock w/stock rails and injectors
    5.7 throttle body and intake
    Inertia Spartan Plus cam, 214/222 566/556 110LSA
    ARH long tubes, 1 3/4" w/cats
    SLP 25% underdrive pulley
    MagnaFlow catback (this was previously my only horsepower mod)
    The car also got:
    New 6.1 pushrods, valvesprings, lifters, timing chain+tensioner, and MDS delete plugs. It also already had a 3.06 Getrag posi.
  8. #23
    Sep 2016
    5.7 hemi, stock
    The car also got:
    so what's it putting down on the dyno? that sounds like a pretty fun very streetable setup.
  9. #24
    Calgary, Alberta
    5.7 hemi, stock
    The car also got:
    I think you meant milled 0.030" (30 thou)
  10. #25
    May 2014
    Virginia Beach, VA
    Nope, the shop only gave it a three thousandth mill to level the head surface.
  11. #26
    May 2014
    Virginia Beach, VA
    Quote Originally Posted by agoristmike View Post
    411rwhp
    If you check my other threads I have a dyno graph posted! It drives very well, with good manners and lots of low end torque to get moving. The last thing I wanted was a dyno queen that made a big horsepower number but lost low end, fortunately the torque and horsepower increased across the board.
  12. #27
    Nov 2017
    Warren, Oh
    We had a member of another forum do 6.1 heads and intake on his truck. Running the stock cam he only showed about 270 wheel hp. Not sure if it was any dyno day errors or what, but man I think the stock cam killed him. He has since put a comp 273 in, I’ll have to look back and see if he did an updated dyno pull
    03 Ram 392 Stroker
  13. #28
    May 2014
    Virginia Beach, VA
    Quote Originally Posted by chrisp2493 View Post
    A pickup is probably not the right application for huge cfm heads on a stock itty-bitty cam.
  14. #29
    Apr 2018
    Boca Raton, Florida
    Is this required to run the 5.7 stock gaskets with 6.1 heads? Now I'm confused lol.
    2006 BB Chrysler 300C 5.7L RWD
    Flowmaster American Thunder Catback, JBA Shorties/Catless Mids, LMI Frankentake IV, 93 Octane Tune, PowerStop Evolution S/D Brakes, 180* T-Stat, 22" Velocity Rims, Street Edge Coilovers, SPC Upper Control Arms/Rear Bushings, Powerbass Amp/Dual 12" Subwoofers, 8000k Led, Smoked Headlights/Fogs/Taillights/Side markers, Black Grill, Tinted
  15. #30
    May 2014
    Virginia Beach, VA
    Quote Originally Posted by Hunter300c View Post
    No, that was just to make sure the head surface was true and flat.
