Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Feb 2017
    glendale az
    Quote Originally Posted by WontStopTheFUnk View Post
    Well it’s still pretty cool. I can see all of the things I can’t normally see. I only have basic analog type gauges so I don’t normally have access to that kind of stuff. It was cool to see the oil pressure. I was also able to see the PCM mileage which was nice considering my cluster is a donor and does not match. We were able to pull up the transmission temperature with my dad‘s torque app.
    Keep in mind the nag1 transmission temp does not read in park, you have to have it in gear to get a accurate temperature.
    Thanks WontStopTheFUnk thanked for this post
    Likes WontStopTheFUnk liked this post
  2. #17
    Calgary, Alberta
    Quote Originally Posted by circ1977 View Post
    Keep in mind the nag1 transmission temp does not read in park, you have to have it in gear to get a accurate temperature. Other wise it will just display the last updated temp since key on.
    Actually, what it displays while in Park is coolant temperature.
  3. #18
    Jul 2018
    Correct. In park it is same as coolant. Temp was read in drive/reverse. Either way, pretty nifty. Wish my iPhone app or predator could do that.
  4. #19
    Feb 2017
    glendale az
    Hmm, my bad, I'd have to check next time I look at one, I thought it displayed the last known in gear temp since key on. So if you put it in park after driving it , it will immediately display coolant temp is what your saying???
  5. #20
    Calgary, Alberta
    Yes, within a few seconds.
  6. #21
    Feb 2017
    glendale az
    I stand corrected, thanks for keeping me honest. Don't know where I got that from but I edited my post as to not confuse future readers.
  7. #22
    Calgary, Alberta
    NO problemo :^D
