Guys need some help. I've got an 04 block that I was just doing a mild rebuild on. 6.1 cam and springs. Crower timing chain and 6.1 pump. I've been kicking back and forth on changing out the rotating assembly. I can across a deal on a full 6.1 assembly. My main concern is the max bore. I've read it should take 4" no problem but then other who claim to have gone 4.055 and ran the 6.1 rotating assembly in them. It's a CB block non mds. Does anyone have any experience in doing this? Block is going to the machine shop his weekend for cleaning and cam bearings. Might see if they can sonic test it as well.
I’m curious what the sonic test will show. I’ve read that it can’t be done many times before as well. Is there cylinder wall differences between your 04 non mds and the regular pre eagle 5.7?
That's what I've read as well. I've read where someone used a few AC blocks as they were said to have thicker walls and he did 3 of those with 6.1 assemblies but haven't read anything on the CB blocks. Heard the early blocks were thicker but who knows
No only upgrades is dynatech long tubes, 6.1 cam advanced either 4 or 6 degrees, intake and exhaust mods, 6.1 dampener and hypertech 93 tune. Will do a dyno tune down the road. It's going in an 04 durango
Doesn't matter what year the pre Eagle 5.7 block is or if it's MDS or not, ,
most will go to 4.0 inch in over bore, sonic the block and go from there, core shift will affect how far you can go. I've gone as big as 4.08 with a 53021319AC block and 4.09 with an 53021319CB the 53021319AG I've gone as large as 4.03 with room to spare, but no rhyme or reason behind any of it, 53021319AC/AG/CB I have one of each that I wouldn't bore more than 4.0 , I have a pair of 6.1's that would not trust to bore out to 4.07 , sonic the block
I was quoted $1000 to clean, bore, square the deck, line hone, and fill the block. So a few hundred less if you don't fill or fill it yourself (as i'm going to)
If you bore the cylinders.....would you need a bigger opening on the headgasket?? It would make sense since the gasket lines up perfectly on a stock bore.
Yes it is. You would need new gaskets anyways. Also depends on the head. Normally you want .010 over bore. But you have to make sure it still seals the chamber design.
If you bore out a 5.7.... to 0.040 over...that would make it a 3.96..... if you were to need bigger gaskets...at that point one could use 6.1 gaskets right?
6.1 is 4.06
5.7 is 3.92
Bored 3.96.
Making it .010 within the limit.
Or am I wrong? It should still seal the chamber correctly .....
yeah head gaskets are not the cheapest. But they are pretty freakin important so you dont want to cheap out there.
You really dont have much of an option. You have to seal the bore and the chamber. If the bore is bigger, then you have to get a bigger gasket.
It sounds like it's said to be "possible" to bore bigger than 4.00.
I'm starting to get confused.... [emoji53][emoji53][emoji53]
And now here.... This suggest the block was bored FROM something to the 4.055 that the 6.1 contains which is over 4.0. Normally, a statement contains the words, "has a bore of" or something similar.
Simple answer is yes, 4 to 4.03 is very doable for the pre Eagle blocks. Arrington will sell you a 410 CI based 5.7 Arrington 410 Short Block - shopHEMI.com , there are no off the shelf pistons for a 4 in bore 5.7 Hemi , you can use some brand X pistons but they need to be modified.
your best bet is Custom pistons from Mahle(SP) or Diamond .
as for a 4.055-4.08 (stock 6.1+) bore 5.7 block, if you find a block that the cores were spot on when it was casted , it's doable, most o3-04s can go 4.055/4.06 I've gone as large as 4.09, I would not do it again , that engine after a year had hots spots in the bore and sure as all he L L would of blown up if it was boosted
. sonic test any block before boring
No one can tell you that your block will go that large. You have to get it sonic checked to see what it will accept. Not every block is the same. Getting it checked is not expensive at all ~$50.
Factory blocks are not perfect. There are core shifts in the manufacturing process. So while most of the cylinders will accept that size. One cylinder may be off center a little and cause a thin spot. Now the manufacturing process have come a long ways so these variances have tightened up a lot. Depending on your machine shop,and how bad the shift is, they can realign the cylinder to be centered but the "thin" spot will be as thick as it ever will be.
Even if the block accepts it, that'll be a one and done. You have to do a teardown or rebuild at any point there's no boring it any further safely; I'd feel better with less displacement and thicker cylinder walls.
I’ve been curious about this for a while. I have a set of 6.1 pistons and rods and got them cheap with low miles, would just need a crank. I have three spare 5.7 blocks sitting in my garage. Been contemplating this and seen that it hasn’t been done much in regards to this topic. Obviously it would sonic tested and I have awesome machine shop / engine builder. I was thinking of doing this with a set of ported eagles and 6.1 intake. Possibly using a .219/.223 cam and / or talking to Dave at MM to see what’s best for this. Kinda just throwing this around.
I would love to do a 5.7 392 with ported eagles but bored 5.7 is more cost effective for me. I could do this almost complete for what a 392 stroker cost. Unfortunately I don’t have all the $$$$ the other guys have on building a motor.
Related Threads
LX Forums Forum
5.2M posts
123K members
Since 2004
