Page 5 of 5 FirstFirst ... 345
Results 61 to 67 of 67
  1. #61
    Aug 2009
    Quote Originally Posted by circ1977 View Post
    Cool project, my friend at work is currently working on his v6 to vvt hemi conversion.
    Wish him luck! As long as it’s not AWD, it’s a quick job.
    05 Magnum AWD SXT Hemi Swap
    instagram.com/hemisxt
  2. #62
    May 2018
    VVT? From What Engine? To What Car? Nice. Wish He Can Share His Experience With Us.
  3. #63
    Feb 2017
    glendale az
    I believe it's an 05 magnum, it's a vvt mds motor so 09 or newer.
  4. #64
    Apr 2014
    Rouyn-Noranda, Québec, Canada
    Yes, I learned this the hard way. Factory parts said I needed a different cradle. $550 later I got the same one I already had. Cost me $40 restocking and $110 to ship back. It was my fault tho. They did send what I ordered.
    Hey, i was wondering if you could provide me with the 5.7l AWD transmission crossmember part# please.
    I need to change mine, bolts were seized because of the aluminum to steel corrosion and it's kinda messed up now. Only have 1 bolt holding the bushing in place and i think it might have failed or is failing...hearing a loud clunk when the tranny downshift...and because i run blue tops, it downshift hard.
    Thanks in advance buddy, also, very great thread!
    2006 Chrysler 300c Awdsome, Intune I-1000 - Johan Custom Tooned - Afe StageII CAI - 180t stat - Corsa Sport Catback - JBA Catted Mids - NoEsp - Coolit - Tranzformer - Blue Tops - KillerGlass - BT Catch Can - Egr Delete - Triple Pod (2x AFR, 1 Trans temp) - HID (Low,High,Fogs,Reverse) - DGS Stage 4 Grounding Kit. And many more to come!
  5. #65
    Aug 2009
    Apr 2014
    Sadly, this is the RWD brace, at least for the first gen like me.
    Thanks for taking the time tho!
  7. #67
    Nov 2017
    Part Number: 4578156AG
    Replaces: 4578156AC, 4578156AD, 4578156AE, 4578156AF
    Description: 3.6L, with awd. 5.7L, with awd, 2011. 5.7L, with awd, 2012-18.
