Results 1 to 11 of 11
Thread: Rim fitment
    Jul 2015
    Rim fitment
    Hi all
    Been a long time since I have been here. I am now back in a mopar and purchased a 2020 300s with a 5.7. Just picked up my new rims and went with Rohana RXF11’s in 20x11 with 20 offset in rear and 20 x10 with 20 offset in the front. The issue I have is the rim seems to rub so minimal on the arm they comes up to connect to the upper control arm. Now if I went with a 5mm spacer I would clear but because I am running a 20x10 in the front it will poke out. Does anyone know if I swap to the SRT/Hellcat hub’s if it will clear. I think they have more of a bow in them. I need to post the pictures all separately so please ignore the multiple post of pictures. A few of them will have red markings to show where the issue is
    Jul 2015
    Jul 2015
    Jul 2015
    This is the Hellcat one. Where the arrow is is where mine rubs
    Jul 2015
    I think mine is is more shaped like this in red
    Jul 2015
    Back is perfect
    Jul 2015
    Side view
    Apr 2016
    You could even run a smaller spacer. I believe stock offset is 15-18mm that was on 5he older generation but I don't see why it would have changed. Most guys who run SRT wheels on non SRT's have to run a small spacer up front because of the wheel backspacing.
    Sent from my Pixel 4 using Tapatalk
    Jul 2015
    Quote Originally Posted by gabbas View Post
    Yes if I run a 5mm spacer it will poke out the front. If you see the top down picture it is already as far out as I would want
    Feb 2019
    Southeast Michigan
    Order a narrower front wheel then, like 9" or 9.5" wide
    And if you don't want crazy sizes front to back...send the 11's back and put the 10's in the rear. That's still plenty of size/tire for a 5.7
    2020 Charger Scat Pack
    Jul 2015
    Quote Originally Posted by snobrdrdan View Post
    It’s all good. I am upgrading to the SRT front hubs now and they clear. So I will be able to run the 20x10 front and 20x11 rears
    Likes snobrdrdan liked this post
