Results 1 to 9 of 9
    Jan 2019
    Tranny cooler - which lines are which?
    Does anyone know FOR SURE which line is incoming and which is outgoing?
    I would assume the top is from the tranny and the bottom is the return back to tranny, but I could be wrong.
    Thanks guys!
    Feb 2018
    Boca Raton, fl
    I would think top return, makes the most sense.
    2013 Chrysler 300S, 6.4 BGE with 6.4 SRT cam, AIT 18% OD pulley, E-force with 2.75 pulley, fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, Magnaflow Cat-back, FTI 2800 stall, Trans built by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. LG aluminum rad. Dual SRT fans. Complete 4 piston Brembo upgrade.
    XIX X39 22x9 - 22x10.5 with NITTO 420 275/40R22 +15 - 295/30R22 +22
    Mar 2014
    FL
    If you look at the transmission there's arrows indicating the direction of flow.
    My 2 Ton Beast
    2007 Black 300 SRT8
    Procharged
    Calgary, Alberta
    What transmission?????????
    May 2015
    Louisiana
    Just power brake it a little then shut it down, the cooler of the two lines is the return.
    Calgary, Alberta
    If it is a NAG1, the return is the bottom hard line when looking at the cooler.
    May 2015
    Louisiana
    At the cooler, yes that makes the most sense. Keeps the filter full as the fluid pushes in from the bottom and flows back out to trans from the top.
    Jan 2019
    8HP45 (8 Spd) not NAG1, cooler integrated into the Condenser.
    Are arrows underneath the car or at the cooler? They transition from hardline to I believe 3/8 rubber hose about 18 inches from the cooler.
    Calgary, Alberta
    Quote Originally Posted by azchrisf View Post
    As with all previous platforms, the transmission cooler is integrated. Arrows indicating flow direction are molded into the housing next to the hard lines. You might check for same on yours.
