Results 1 to 6 of 6
Thread: Will it rub ??
    Mar 2019
    Will it rub ??
    Ok so I have some Asanti 5’s black labels on a 2017 300c. At the moment I am running front:265/35/22 Rear:285/35/22. I just replace the front set of tires same size but for the rears I want to run a wider tire so my rim lip won’t stick out as much, so just wondering what would be the best size to run. will 295/35/22 fit without rubbing and also could I possibly fit 305/30/22 without rubbing?
    P.S. -Stock ride height
    -Front wheel: 22x9
    -Rear wheel: 22x10.5
    Jul 2017
    I am running the 295's and they rub on occasion if I have someone in the back seat.
    2012 300 SRT8: 22" Vossen wheels, Nitto 420 265/35/22 front and 295/30/22 rear, SLP Bigmouth II exhaust, Tuned by Hemifever, Mishimoto 180° stat, Legmaker Tru CAI, Billet tech Oil Catch can.
    I am silently correcting you're gramar and speling.
    Mar 2019
    Your* lmao but thanks for trying. So pretty much what you’re saying is if I have passengers it will scrub and without I’ll be good ?
    Jul 2017
    Quote Originally Posted by MyMopar3 View Post
    Your* lmao but thanks for trying������. So pretty much what you’re saying is if I have passengers it will scrub and without I’ll be good ?
    I don't understand this "Your* lmao but thanks for trying������" but you might be in better shape as you are at stock ride height. Mine is an SRT so it sits a little lower.
    Feb 2018
    Boca Raton, fl
    I'm running 295s and had to roll fenders.
    2013 Chrysler 300S, 6.4 BGE with 6.4 SRT cam, AIT 18% OD pulley, E-force with 2.75 pulley, fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, Magnaflow Cat-back, FTI 2800 stall, Trans built by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. LG aluminum rad. Dual SRT fans. Complete 4 piston Brembo upgrade.
    Feb 2018
    Boca Raton, fl
    On MOPAR Stage one springs.
