Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Aug 2015
    There's definitely something wrong. I'm in Florida and when it's 80 degrees here even during Winter months, I can tell it's not working! I turn it off and on a couple times and suddenly ice cold air. I do run the a/c periodically to keep system lubricated. Thanks.
  2. #17
    Feb 2018
    Boca Raton, fl
    When you push the recir button does the light stay on or flash and go out?
    13 Chrysler 300S, Stock 17 RAM 6.4 BGE with TSP Stage 4 boosted Cam, AIT 18% OD pulley, E-force 2.62 pulley(12.2 lbs boost),, Fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, 3" Magnaflow Cat-back, FTI 2800 stall, Trans by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. aluminum rad. SRT fans. Brembo upgrade. Stage one MOPAR springs, XIX X39 22x9 +15 - 22x10.5 +22 with NITTO NT555 265/35R22 - 295/30R22
  3. #18
    Aug 2015
    Light stays on
  4. #19
    Feb 2018
    Boca Raton, fl
    Maybe a failing relay?
  5. #20
    Dec 2019
    Humidity sensor (behind mirror)? Activate "Auto" and press "Recirculate", should hear blend door closing. If not, door or actuator stuck.
  6. #21
    Aug 2015
    Well I can FINALLY tell you what was wrong. To my surprise, it was the A/C clutch relay! I would have never thought a fuse relay would be intermittent! You would think they are either good or bad (wouldn't you?). The A/C finally stopped coming on altogether instead of after several tries of the on/off button. So for the heck of it, never expecting it to work, I pulled the wiper relay and stuck it in the a/c clutch spot, and bingo, ice cold air again! It's been working ever since, and it's been about two weeks. Simple $15 fix!
    Likes jdm7 liked this post
